I am pondering about buying a Creality Ender-3, and I am honestly confused about some reviews. Some claim it is running 24 V, one did claim it was 12 V, most don't mention it. Since I know about some issues with the clamps, if I get myself an Ender-3, I want to replace the hotend with a proper one from day one. So knowing its voltage is needed to order the right parts.
Asked
Active
Viewed 5.2k times
Bearing in mind that the specifications on Amazon's page are sometimes not 100% (even though they are in this case), it is always best to check on the manufacturer's website.
From Creality3D's own website, Creality3D.shop, on the Creality3D Ender-3 product page, Creality3D Ender-3 3D Printer Economic Ender DIY KITS, the specifications are given as (emphasis is mine):
##ender-3 Machine Parameter:
- Modeling Technology:FDM (Fused Deposition Modeling)
- Printing Size:220220250mm
- Machine Size:440410465mm
- Package weight:8kg Max
- Traveling Speed:180mm/s
- Filament:1.75mm PLA,TPU,ABS
- Input:AC 100-265V 50-60Hz
- Output:DC 24V 15A 360W
- Layer Thickness:0.1-0.4mm
- Nozzle diameter:0.4mm
- Precision:±0.1mm
- File Format:STL,OBJ,G-Code
- Working Mode:Online or SD offline
- Max Nozzle Temperature:255℃
- Max Hot bed Temperature:110℃
Eli TheHuman
- 155
- 8
- 7
- 30
- 60
4Attention! Creality3d.shop is not the real shop https://www.creality3donline.com is the real online store. this information appears correct though, as it's probably just ripped from the official online store. – Nilloc Jan 24 '19 at 19:05
Ah ok, my mistake, thanks for the clarification – Greenonline Feb 06 '19 at 16:03
2The Creality shop is now https://www.creality3dofficial.com/, as said on their site https://www.creality.com/ (online shop link) – Eli TheHuman Jun 23 '20 at 22:18
The Ender 3 and the CR-10 printers use the same board which runs on both 12V and 24V. I have one of each and have to be careful swapping parts between the two.
Dave Corbett
- 111
- 4
Really? That is very interesting to know. Please see [What specifications of the dual voltage controller of the Ender 3/CR-10?](https://3dprinting.stackexchange.com/questions/6524/what-specifications-of-the-controller-of-the-creality-3d-3) – Greenonline Aug 01 '18 at 05:53
1I'll go poking around with my voltmeter this weekend and report what I find. – Dave Corbett Aug 02 '18 at 13:39
