When I try to print something that is not the test model already on the SD, which means when I try to slice something in Cura 4 and than I start the print, the nozzle stops at Z=15 mm and only the extruder motor goes foward and backward. I tried to modify the G-code but I didn't solve the problem. I need help because it's my first delta 3D printer and I don't know what to do.
Asked
Active
Viewed 128 times
1Can you add an image of your print and the stl image? – Fernando Baltazar May 14 '20 at 05:03
1Did you use the pre-configured profile in Cura? – coat May 15 '20 at 19:52
have you configured z-offset yet? – linuxdan May 26 '20 at 04:40
