I understand the purpose of printing with a skirt (or at least, I think I do): it gets the filament warmed up and flowing properly, in order to avoid extrusion problems while starting to print the first layer. (Perhaps it has other benefits as well? If so, I'd be interested to know what they are.)
However, what's not clear to me is why skirts are set up in exactly the way they are. In particular:
  • Why is the skirt drawn around the whole of the outside of the print, at a roughly constant distance from it, instead of (for example) just going round in a small circle in one corner of the print bed?
  • Why does a print with a larger first layer need a skirt that uses more material?
I ask partly out of curiosity, but also partly because I'm printing several small but awkwardly shaped parts, and using a skirt reduces the usable area of the build plate. If the skirt could just be put in one corner instead of going all the way around the edge I would be able to fit more parts on the build plate. This leads me to my final question:
  • In Cura, can I change the layout of the skirt, so that it gets drawn in a convenient part of the build platform, instead of going all the way around the edge of the print?
N. Virgo
  • 1,489
  • 14
  • 25
  • if I skip the skirt, how else can I bust my knuckles and smash my fingernails frantically adjusting the leveling as it starts to print? – dandavis Jan 21 '20 at 19:08
Skirt and Brim are not only nozzle prime operations. While Brim is intended to help in adhesion by increasing the area, Skirt is a method to test some things about the bed and positioning:
  • If the bed is unlevel, you can see this in the skirt before the print starts. This demands to go around all of the print.
  • If the bed is greasy, you'll see also before the actual print starts, as the extrusion does not stick well.
  • It provides a visual check if the slicing is positioned well on the printer. If you for example run printers of different dimensions, the skirt shows instantly, if you loaded G-code that is too large for the bed.
The effect to reduce airdraft to the first layer is sometimes brought up, but I don't think it is relevant. However, if one would pause between skirt and print, one could use the outline to put down glue or ABS-slurry for materials that need extra adhesion.
The use of the material in a skirt is directly proportial to the width (1 or 2 lines) and the area included (as circumference is proportional to area).
No. Skirt is, by definition always around the whole set of parts. Just turn off Skirt and use an alternate priming, if you don't think you'll need it or find it cumbersome. Instructions for example priming operations can be found in Writing G-code : swiping at start of print
