Flsun 3D Cube; Marlin 1.1.1; main board: Makerbase MKS Gen_L V1.0; running from either Repetier or OctoPrint.
I was recently obliged to replace the main board when it stopped powering the heated bed. I got the new main board - same make, version, etc - got everything setup just as it was before, but the bed still doesn't heat. Multimeter shows zero across the board's heat bed contacts, whether using G-code from the terminal (in both Repetier and Octoprint), G-code in the print file, or the control panel on the front of the printer. The thermistor works: if I shine a heat lamp on the bed, it registers the temp change.
Bad board? Something in the Merlin config I missed? Is the board smart enough to not power it on if the bed heater itself is bad?
