I want to print this heat tower calibration test.
The instructions say to change the temperature every 25 layers. It also tells me to use G-Code command M104 Sxxx
First, is there a way to specify this command using Ultimaker Cura?
If not, how do I do so in the G-code file?
I see that the G-code file is just a plain text file with a command per line presumably. Do I just insert M104 S225 at one point and then M104 S220...?
If so, how do I know where the 25th layer is?
