Let's say I'm modeling a simple open-top rectangular box to slice via Cura for printing. Normally I would set up a solid box of the size I want in the modeler, and then subtract a slightly smaller box to create the final result.
  • Is it possible to get the same results with Cura by instead only modeling the simpler solid box if set my wall lines and thickness for the base and sides, set the infill to 0 %, and then set the Top Layers to 0 and/or Top Thickness to 0 mm?
  • How might that change the resulting print?
  • How will that impact the total height of the print?
Joel Coehoorn
  • 2,115
Yes that will work in Ultimaker Cura exactly as you say.
So if you have a solid model of a cube, you select wall thickness, bottom thickness, 0 % infill, and no top layers or top layer size of 0 mm. You will then end up with a box without a top layer, but with walls reaching up to the height of your model.
