I'm working on developing alternative infill layers to print at different angles, using Slic3r. Using Slic3r's rectilinear infill, printing at specific angles for 3 layers then repeat.
I'm working towards finding the code in the source code where they alternate the layers and change it to alternate it for every 3 layers.
I know I will need some C++ knowledge to fiddle around with the Slic3r's source code, but if there is someone who can point me in the right direction I would gladly appreciate it!
Jiong Le
  • 71
Slic3r is available on Github.
I think the section you'd be looking for is here
Matt
  • Yups! Thank you for the comment! I have found that by changing the out angle you can command the angle at your will (Of course in programming terms). – Jiong Le Apr 25 '17 at 01:34
