17
As an extension from this question, is there any reason that you would not be able to use 1.75 mm filament in a printer that takes 3mm filament? I know you would have to change the filament size in the slicing of prints but would there be any other problems?
Also, would using 1.75 mm filament be possible if the nozzle diameter was greater than 1.75 mm but less than 3 mm?
Eric Johnson
  • 2,228
  • 39
  • Perhaps you should restrict the question to a specific printer, and the part about the 1.75mm nozzle should probably be a question in its own right (though it is right on the edge of what I'd consider a good-quality question, considering the answer will just be "no"). – Tom van der Zanden Jan 15 '16 at 13:35
  • I was mainly asking this as a hypothetical question based off the previous question I mentioned. For the 1.75mm nozzle, I added that part to clarify what I assume the answer to the first part will be. I assume that 1.75mm could be used, but only if it was smaller than the nozzle. if you normally were using 3mm with a 2.5mm nozzle, 1.75 should not work. – Eric Johnson Jan 15 '16 at 13:40
  • There are some setups that can accept both with only minor configuration changes. The stock hotend for the H-1 is one example. You slip you mostly slip in an extra tube, and slide the hot end over to the over end of the knurled bolt and you're good to go. – BrainSlugs83 Oct 08 '16 at 06:10
Typically an extruder and hot end are designed for one or the other, and cannot support the other without mechanical changes.
The extruder may not be able to grip a smaller diameter filament with enough force to assure even feeding and retraction.
The hot end, however, is much more complex. The filament has to be pushed with force into the melting zone, which means the filament has to slide along an area inside the hot end where the filament is plastic but still put pressure on the filament ahead of it.
When you put filament into a hot end, the filament softens before the melt zone, but since the walls of the hot end are just barely larger than the filament it has no choice but to continue pressing down on the liquid filament below.
With a narrower diameter filament, though, the filament can heat, soften, then travel backwards along the sides of the hot end and cool in place, jamming the hot end, or at least preventing an even continuous flow of plastic.
Some hot ends will accept a small Teflon tube that takes this space up and allows you to do this with fewer issues, and if you like to tinker you can experiment with this, but be prepared to learn a lot and fail a lot as you find out the hard lessons of hot end design.
Generally you should upgrade your entire extruder and hot end setup to the size you want to use.
Adam Davis
  • 1,813
  1. It may work for a short time but you're going to fill the melt chamber quickly and possibly overflow to a point where the filament isn't constrained causing a messy jam. All the molten plastic will likely flow backwards to a point where the diameter isn't 3mm any longer (probably next to your drive gear) but depending on the length it may just flow up, cool down and jam the extruder.
  2. No, the filament would just pass through unheated and not do anything.
tjb1
  • 2,090
  • 14
  • 26
  • I don't understand why it would overflow. OP correctly mentioned that the settings would have to be changed; but once that's done, wouldn't the software turn the extruder motor only 1/3 as far to extrude the same volume of filament? – TextGeek Jan 15 '16 at 17:01
  • In most cases, the gap around the filament would be larger than the hole in the nozzle. I don't know the math to figure it out but I am assuming it would take less pressure for the molten plastic to go backwards through the larger gap than through the nozzle itself. – tjb1 Jan 15 '16 at 17:18
  • Now I have to go try this. My intuition differs, but the best way to know for sure is for us to try it... :) – TextGeek Jan 15 '16 at 17:32
  • You just need a teflon liner to prevent this issue (that's what the H-1 used to overcome this problem). – BrainSlugs83 Oct 08 '16 at 06:11
