I'm having some problem with my Ender 3. I have been printing for almost a year with good results. Then, all of a sudden, the fan started to be noisy and the prints came out definitely not good.
From what I understood looking around, the problem could be under extrusion.
I replaced the fan (both of them actually) but the prints keep coming out badly. The software is always the same (Cura) and I never changed any parameter whatsoever.
This is what I tried so far:
  • printing with (four) different filaments (always PLA though).
  • changing the E-steps
  • unclogging and replacing the nozzle (twice)
  • re-calibrating Z like a million times
  • printing different projects, included those who I already successfully printed before
-> Nothing helped!
Then I was forced to also change the software (because my PC died...) But even with the new version nothing changed. Now the extruder calibration is okay (I print 10 cm and 10 cm of filament are consumed through a hot nozzle).
Increasing the flow by 5 % and the temperature by 10 °C (I'm now printing at 220 °C....) actually gives better results (the calibration cube is more definite and more solid) even if under extrusion is still appreciable.
Calibration cubes: Calibration cubes (before and after increasing flow and temp)
Printing example: Printing example
I don't know what else to try!!! Can someone help me?
  • Hi, welcome to 3DPrinting.SE! Indeed, under extrusion seems to be the problem. From the second image it looks as if the print started out fine, but under extrudes in the upper regions. The images aren't very clear. How did you test the extruder calibration, with or without nozzle? – 0scar Nov 17 '22 at 09:31
  • It's just because of the picture...under extrusion is present from start to end :( i tested the calibration with nozzle – user3263713 Nov 17 '22 at 10:47
You are pushing 10 cm through a hot nozzle for calibration, this is sometimes different in terms of pushing it under load (back pressure from the deposition/squishing of the filament). Although the correct calibration, the prints are under extruded, so there is too less filament delivered to the nozzle.
This hints to a problem with the extruder; these type of extruders are known not to be the best type of extruders, common problems with these extruders are a lack of idler wheel tension, broken and cracked extruder lever and wearing out of the brass extruder gear.
You should closely check the extruder during printing, it is expected that not enough filament is pushed forward to the hot end. You could increase the tension on the lever, but is is probably best to invest in a better Bowden extruder, preferably using a dual gear and/or using a gear ratio (for more torque). Note that you may require buying a new stepper motor as well: Problems with stock gear with no screw on Ender 3 pro.
