I have just set my extruder nozzle to 0-0 by moving the X & Y limit switches. The print is still starting very close to 0-0. How can I move the Extruder to the centre of the plate. I am using an Anet A8 printer with Cura slicing software and Marlin firmware
Asked
Active
Viewed 34 times
2Where you slice it is where you print it. If it isn't, your slicer is misconfigured or your firmware is not configured correctly. For the latter you could look into "[How to center my prints on the build platform? (Re-calibrate homing offset)](https://3dprinting.stackexchange.com/questions/6375/how-to-center-my-prints-on-the-build-platform-re-calibrate-homing-offset)". But, please provide more information by [edit] of your question, provide images of the sliced print location and the printed location. Welcome to 3DPrinting.SE! – 0scar Sep 05 '22 at 05:41
2Thanks for adding some information, but, this isn't enough to answer your question! Do you mean that even with the change in position of the end stops the printer does not go to the corner of the heated bed (i.e. origin [0, 0])? Please add pictures after printing [this print](https://www.thingiverse.com/thing:2280529). P.S. when slicing in Cura make sure the printer machine setting `Origin at center` is **not** checked! If the printer is not getting to the origin when commanded your end stop offsets might need tuning. – 0scar Sep 05 '22 at 11:42
