I have a Creality CR-6 SE running Community firmware. It's printing mostly well, in part because it's improvisationally enclosed (sheets of cardboard between it and the closes window to reduce draft, which was killing my prints on bad days). To make it moderately shock-resistant it's placed on a 50x50 cm concrete tile which is placed on 3 mm of foam. The foam reduces vibrations being redirected to the tile while the tile is heavy enough not to care either way.
Now it has to move because I want to move my desk into the same room as the printer.
This means 2 things:
- My and my printer will be getting their required ventilation from the same window, but sitting in the same room as a printer for 8+ hours a day isn't a great idea if we breathe the same air. Either I need to scrub the printer exhaust or pipe it out (totally doable, it's not that far).
- Either I have to sit very quietly or the printer has to be placed somewhat shock-proof. The floor itself is of wood and on the first floor, so there's some minor bounce in it. It's not 100% level and it gets (slightly) worse if you stand next to it.
I've been thinking about making a towered enclosure (roughly like the famous Lack approach). However, if I construct a tower, the increased position vector between ground and printer could make the printer shake. Besides, a simple Lack won't work because PLA won't like being confined. Where other materials like getting hot, PLA likes to be ventilated. The obvious solution would be a couple of fans that can be shut-off and covered, but maybe I'm thinking too complicated already. Either way, that's a fixable problem.
See-through sheet work is likely going to be done with 2mm plexiglass (acrylic, PMMA).
I'm currently printing PLA 100% of the time but the enclosure should be able to handle PLA, ABS, and PETG. There's a Raspberry Pi available, so requiring different settings for different materials is not a problem either.
So I can fix all problems, except the shock one. More fans mean more vibrations, so it will get plenty of shocks by itself. Add the shocks of me walking past it, especially if the printer is in a tower, and you can wait for failed prints.
I've seen people put their printers on springs, but is that the best way to deal with it in enclosures? Would it make sense to put the tower on top of the existing foam/concrete base or would it be better to catch the shocks as close to the printer as possible?
