Whenever I print, the walls separate when genial pressure is applied, this only happens to one side of the print, the side that faces the rear of the printer. I'm using 5 walls, so it’s only truly noticeable on the outer most walls, I’m sure it continues if I peel away more layers (the walls are printed first, then the infill). The print still looks “okay” so I only found out this issue after post-processing a prior print.
I’ve re-leveled the build plate and confirmed it with a bed visualizer.
I have attempted to shim that side of the print bed up.
I installed new belt tensioners to rule out belt tension.
I’m not sure what else to do, I rather not increase my flow or E-steps as the print dimensions are already pretty good and I don’t want to risk over extruding to solve my issue despite how it would fix the problem. I would be sacrificing accuracy for print coherency then.
  • I print on an Ender 5 plus
  • Slicer is Cura
  • Print speed is 60 mm/s
  • Printing at 220 °C for the hotend
  • Filament is Makerbot PLA
Adrian
  • 61
