Don't support bridge is a good idea to reduce support with acceptable print quality. But in this case, if I have a very long bridge and a short bridge, how do I tell the slicer to generate support only for the long bridge. How can I set some parameter like bridge length threshold?
1Please clarify, do you want support for the long or short bridge. Your title question doesn't match with what is mentioned in the body. – agarza Apr 15 '21 at 16:39
@agarza I just edit my question. – M lab Apr 15 '21 at 20:40
Regardless of the choice of long bridge support or short bridge support, Prusa Slicer 2.3.0 has a feature which allows forced support or allows forced no support.
In Advanced or Expert mode, there is an icon in the left tool bar for "paint-on" supports. The left mouse button paints on supports, while the right mouse button creates support blockers. Shift-left mouse button erases errant paint splatters.
There are more details in the linked video. It's not a parameter, but it is a means to determine where you want (or don't want) the supports.
According to a thread in the Prusa support forum, in order to have the enforcer and blockers operate as expected, configuration settings should be for supports off. This may have changed as the thread is older and may have been modified in newer releases.
- 10,532
- 24
Your answer is useful but I forgot to tell you that I used prusa slicer in repetier host. If there are no solution in repetier host I might change the slicer. – M lab Apr 17 '21 at 11:54
