Code from Celtic's answer:
# generated by PrusaSlicer 2.3.0+win64 on 2021-04-17 at 15:16:02 UTC
[print:BIQU B1 - Standard]
avoid_crossing_perimeters = 1
avoid_crossing_perimeters_max_detour = 75%
bottom_fill_pattern = monotonic
bottom_solid_layers = 4
bottom_solid_min_thickness = 0
bridge_acceleration = 0
bridge_angle = 0
bridge_flow_ratio = 1
bridge_speed = 50
brim_width = 0
clip_multipart_objects = 1
compatible_printers =
compatible_printers_condition =
complete_objects = 0
default_acceleration = 0
dont_support_bridges = 1
draft_shield = 0
elefant_foot_compensation = 0
ensure_vertical_shell_thickness = 0
external_perimeter_extrusion_width = 0
external_perimeter_speed = 50%
external_perimeters_first = 0
extra_perimeters = 1
extruder_clearance_height = 20
extruder_clearance_radius = 20
extrusion_width = 0.4
fill_angle = 45
fill_density = 20%
fill_pattern = cubic
first_layer_acceleration = 0
first_layer_extrusion_width = 0
first_layer_height = 0.28
first_layer_speed = 20
gap_fill_speed = 20
gcode_comments = 0
gcode_label_objects = 0
infill_acceleration = 0
infill_anchor = 600%
infill_anchor_max = 50
infill_every_layers = 1
infill_extruder = 1
infill_extrusion_width = 0.48
infill_first = 0
infill_only_where_needed = 0
infill_overlap = 30%
infill_speed = 60
inherits =
interface_shells = 0
ironing = 0
ironing_flowrate = 15%
ironing_spacing = 0.1
ironing_speed = 15
ironing_type = top
layer_height = 0.2
max_print_speed = 80
max_volumetric_speed = 0
min_skirt_length = 50
notes =
only_retract_when_crossing_perimeters = 1
ooze_prevention = 0
output_filename_format = [input_filename_base].gcode
overhangs = 1
perimeter_acceleration = 0
perimeter_extruder = 1
perimeters = 4
post_process =
print_settings_id =
raft_layers = 0
resolution = 0
seam_position = aligned
single_extruder_multi_material_priming = 1
skirt_distance = 5
skirt_height = 1
skirts = 1
slice_closing_radius = 0.049
small_perimeter_speed = 40%
solid_infill_below_area = 70
solid_infill_every_layers = 0
solid_infill_extruder = 1
solid_infill_extrusion_width = 0
solid_infill_speed = 50%
spiral_vase = 0
standby_temperature_delta = -5
support_material = 0
support_material_angle = 0
support_material_auto = 1
support_material_buildplate_only = 0
support_material_contact_distance = 0.2
support_material_enforce_layers = 0
support_material_extruder = 1
support_material_extrusion_width = 0.35
support_material_interface_contact_loops = 0
support_material_interface_extruder = 1
support_material_interface_layers = 3
support_material_interface_spacing = 0
support_material_interface_speed = 100%
support_material_pattern = rectilinear
support_material_spacing = 2.5
support_material_speed = 60
support_material_synchronize_layers = 0
support_material_threshold = 0
support_material_with_sheath = 1
support_material_xy_spacing = 50%
thin_walls = 0
threads = 24
top_fill_pattern = monotonic
top_infill_extrusion_width = 0
top_solid_infill_speed = 80%
top_solid_layers = 4
top_solid_min_thickness = 0
travel_speed = 150
wipe_tower = 0
wipe_tower_bridging = 10
wipe_tower_no_sparse_layers = 0
wipe_tower_rotation_angle = 0
wipe_tower_width = 60
wipe_tower_x = 180
wipe_tower_y = 140
xy_size_compensation = 0
[filament:BIQU B1 - GSDT - PLA+ Silver]
bed_temperature = 50
bridge_fan_speed = 100
compatible_prints =
compatible_prints_condition =
cooling = 1
disable_fan_first_layers = 1
end_filament_gcode = "; Filament-specific end gcode \n;END gcode for filament\n"
extrusion_multiplier = 1
fan_always_on = 1
fan_below_layer_time = 100
filament_colour = #8B8B8B
filament_cooling_final_speed = 3.4
filament_cooling_initial_speed = 2.2
filament_cooling_moves = 4
filament_cost = 1000
filament_density = 1.3
filament_deretract_speed = nil
filament_diameter = 1.75
filament_load_time = 0
filament_loading_speed = 28
filament_loading_speed_start = 3
filament_max_volumetric_speed = 0
filament_minimal_purge_on_wipe_tower = 15
filament_notes = ""
filament_ramming_parameters = "120 100 6.6 6.8 7.2 7.6 7.9 8.2 8.7 9.4 9.9 10.0| 0.05 6.6 0.45 6.8 0.95 7.8 1.45 8.3 1.95 9.7 2.45 10 2.95 7.6 3.45 7.6 3.95 7.6 4.45 7.6 4.95 7.6"
filament_retract_before_travel = nil
filament_retract_before_wipe = nil
filament_retract_layer_change = nil
filament_retract_length = nil
filament_retract_lift = nil
filament_retract_lift_above = nil
filament_retract_lift_below = nil
filament_retract_restart_extra = nil
filament_retract_speed = nil
filament_settings_id = ""
filament_soluble = 0
filament_spool_weight = 1000
filament_toolchange_delay = 0
filament_type = PLA
filament_unload_time = 0
filament_unloading_speed = 90
filament_unloading_speed_start = 100
filament_vendor = (Unknown)
filament_wipe = nil
first_layer_bed_temperature = 50
first_layer_temperature = 195
full_fan_speed_layer = 4
inherits =
max_fan_speed = 100
min_fan_speed = 100
min_print_speed = 10
slowdown_below_layer_time = 10
start_filament_gcode = "; Filament gcode\n"
temperature = 195
[filament:BIQU B1 - PETG]
bed_temperature = 70
bridge_fan_speed = 35
compatible_prints =
cooling = 1
disable_fan_first_layers = 3
fan_always_on = 1
filament_colour = #29B2B2
filament_cost = 0
filament_density = 0
filament_notes = ""
filament_retract_length = 4
filament_spool_weight = 0
filament_type = PET
filament_wipe = nil
first_layer_bed_temperature = 75
first_layer_temperature = 235
full_fan_speed_layer = 0
inherits =
max_fan_speed = 35
min_fan_speed = 35
min_print_speed = 15
slowdown_below_layer_time = 20
temperature = 235
[printer:BIQU B1 (No Z Hop)]
bed_custom_model =
bed_custom_texture =
bed_shape = 0x0,235x0,235x235,0x235
before_layer_gcode = ;LAYER:[layer_num]
between_objects_gcode =
color_change_gcode = M600
cooling_tube_length = 5
cooling_tube_retraction = 91.5
default_filament_profile = ""
default_print_profile =
deretract_speed = 0
end_gcode = ;BIQU Default End Gcode\nG91 ;Relative positioning\nG1 E-2 F2700 ;Retract a bit\nG1 E-2 Z0.2 F2400 ;Retract a bit more and raise Z\nG1 X5 Y5 F3000 ;Wipe out\nG1 Z10;Raise Z by 10mm\nG90 ;Return to absolute positionning\nG1 X0 Y235 ;TaDaaaa\nM106 S0 ;Turn-off fan\nM104 S0 ;Turn-off hotend\nM140 S0 ;Turn-off bed\nM84 X Y E ;Disable all steppers but Z
extra_loading_move = -2
extruder_colour = ""
extruder_offset = 0x0
gcode_flavor = marlin
high_current_on_filament_swap = 0
host_type = octoprint
inherits =
layer_gcode =
machine_limits_usage = emit_to_gcode
machine_max_acceleration_e = 5000,5000
machine_max_acceleration_extruding = 500,1250
machine_max_acceleration_retracting = 1000,1250
machine_max_acceleration_x = 500,1000
machine_max_acceleration_y = 500,1000
machine_max_acceleration_z = 100,200
machine_max_feedrate_e = 75,120
machine_max_feedrate_x = 250,200
machine_max_feedrate_y = 250,200
machine_max_feedrate_z = 10,12
machine_max_jerk_e = 2.5,2.5
machine_max_jerk_x = 8,10
machine_max_jerk_y = 8,10
machine_max_jerk_z = 0.2,0.4
machine_min_extruding_rate = 0,0
machine_min_travel_rate = 0,0
max_layer_height = 0
max_print_height = 270
min_layer_height = 0.07
nozzle_diameter = 0.4
parking_pos_retraction = 92
pause_print_gcode = M601
print_host =
printer_model =
printer_notes =
printer_settings_id =
printer_technology = FFF
printer_variant =
printer_vendor =
printhost_apikey =
printhost_cafile =
remaining_times = 0
retract_before_travel = 1.5
retract_before_wipe = 0%
retract_layer_change = 0
retract_length = 7
retract_length_toolchange = 10
retract_lift = 0
retract_lift_above = 0
retract_lift_below = 0
retract_restart_extra = 0
retract_restart_extra_toolchange = 0
retract_speed = 70
silent_mode = 0
single_extruder_multi_material = 0
start_gcode = M220 S100 ;Reset Feedrate\nM221 S100 ;Reset Flowrate\nG28 ;Home\nG92 E0 ;Reset Extruder\nG1 Z2.0 F3000 ;Move Z Axis up\nM109 S{first_layer_temperature[0]}; Preheat hotend\nG1 X10.1 Y20 Z0.28 F5000.0 ;Move to start position\nG1 X10.1 Y200.0 Z0.28 F1500.0 E15 ;Draw the first line\nG1 X10.4 Y200.0 Z0.28 F5000.0 ;Move to side a little\nG1 X10.4 Y20 Z0.28 F1500.0 E30 ;Draw the second line\nG92 E0 ;Reset Extruder\nG1 Z2.0 F3000 ;Move Z Axis up
template_custom_gcode =
thumbnails =
toolchange_gcode =
use_firmware_retraction = 0
use_relative_e_distances = 0
use_volumetric_e = 0
variable_layer_height = 0
wipe = 0
z_offset = 0
[printer:BIQU B1 (With Z Hop)]
bed_custom_model =
deretract_speed = 0
inherits =
layer_gcode =
print_host =
printer_model =
printer_notes =
printer_variant =
printer_vendor =
printhost_apikey =
printhost_cafile =
remaining_times = 0
retract_length = 7
retract_lift = 1
retract_speed = 70
silent_mode = 0
thumbnails =
toolchange_gcode =
wipe = 0
z_offset = 0
[printer:BIQU B1 Alpha v1]
bed_custom_model =
deretract_speed = 35
inherits =
layer_gcode =
machine_max_feedrate_x = 500,200
machine_max_feedrate_y = 500,200
machine_max_jerk_e = 5,2.5
machine_max_jerk_z = 0.4,0.4
print_host =
printer_model =
printer_notes =
printer_variant =
printer_vendor =
printhost_apikey =
printhost_cafile =
remaining_times = 0
retract_length = 3
retract_lift = 0
retract_speed = 70
silent_mode = 0
thumbnails =
toolchange_gcode =
wipe = 0
z_offset = 0
[printer:BIQU B1 Alpha v2]
bed_custom_model =
inherits =
layer_gcode =
print_host =
printer_model =
printer_notes =
printer_variant =
printer_vendor =
printhost_apikey =
printhost_cafile =
remaining_times = 0
retract_length = 7
retract_lift = 0
retract_speed = 70
silent_mode = 0
thumbnails =
toolchange_gcode =
wipe = 0
z_offset = 0
[printer:BIQU B1 Alpha v3]
bed_custom_model =
inherits =
layer_gcode =
print_host =
printer_model =
printer_notes =
printer_variant =
printer_vendor =
printhost_apikey =
printhost_cafile =
remaining_times = 0
retract_length = 4
retract_lift = 0
retract_speed = 70
silent_mode = 0
thumbnails =
toolchange_gcode =
wipe = 0
z_offset = 0
[printer:BIQU B1 Alpha v4]
bed_custom_model =
inherits =
layer_gcode =
print_host =
printer_model =
printer_notes =
printer_variant =
printer_vendor =
printhost_apikey =
printhost_cafile =
remaining_times = 0
retract_length = 4
retract_lift = 0
retract_speed = 70
silent_mode = 0
thumbnails =
toolchange_gcode =
wipe = 0
z_offset = 0
[printer:BIQU B1 Beta v1]
bed_custom_model =
deretract_speed = 0
inherits =
layer_gcode =
print_host =
printer_model =
printer_notes =
printer_variant =
printer_vendor =
printhost_apikey =
printhost_cafile =
remaining_times = 0
retract_length = 7
retract_lift = 0
retract_speed = 70
silent_mode = 0
thumbnails =
toolchange_gcode =
wipe = 0
z_offset = 0
[printer:BIQU B1 Beta v2]
bed_custom_model =
deretract_speed = 0
inherits =
layer_gcode =
print_host =
printer_model =
printer_notes =
printer_variant =
printer_vendor =
printhost_apikey =
printhost_cafile =
remaining_times = 0
retract_length = 7.5
retract_lift = 0.5
retract_speed = 70
silent_mode = 0
thumbnails =
toolchange_gcode =
wipe = 0
z_offset = 0
[presets]
print = BIQU B1 - Standard
sla_print =
sla_material =
printer = BIQU B1 (With Z Hop)
filament = BIQU B1 - GSDT - PLA+ Silver
