I've recently noticed that the pulley driving the X-axis belt on my Anet A8 is wobbling quite a lot. I took out my calipers and sure enough the hole wasn't centred. I ordered a new pulley (from a different manufacturer) which arrived today but it was also wobbling, though much less than my old one.
The X-axis motor does not appear to wobble at all, I've tried placing a straight object up against the shaft and ran the motor and could not perceive and wobble at all in the motor, so I know it's not the motor. Before I start ordering more of the same part I wanted to see if anyone else has had this problem or if I'm doing something else wrong (for example if the uncentered pulley is a feature and there's some magical way to mount the belt pulley onto the motor to make sure it does not wobble). My guess is that I've just ordered cheap scrap parts and need to order something more expensive.
Here is a link to a video of the wobble: https://imgur.com/o4EJ9pg
  • What type of wobble? Assume Z is along the axis: is the pulley moving in XY (uncentered hole), is it wobbling in Z (axis and hole are angled to one another), is it wobbling as a whole? a photo or short film might help. Reasons for any wobble can be the parts, but it also can be mounting method. – Trish Sep 10 '20 at 09:32
  • The hole is uncentered, there’s also a tiny angle to it, but the majority of the wobble comes from the hole being uncentered. – Beacon of Wierd Sep 10 '20 at 10:49
  • Can you provide measurements / type? – Trish Sep 10 '20 at 11:26
  • https://www.banggood.com/Anet-GT2-Pulley-16-Teeth-Bore-5MM-Timing-Gear-Alumium-For-GT2-Belt-Width-6MM-3D-Printer-Accessories-p-1036136.html?rmmds=myorder&cur_warehouse=CN That's the part I currently have, it wobbles less than my previous gear, but still wobbles. – Beacon of Wierd Sep 10 '20 at 11:29
  • @BeaconofWierd I've order multiple pulleys from AliExpress, never had a problem. Please post photos of the pulley. What can be a problem is that when the center bore is too large, the set screw will offset the center. Please measure the bore and the stepper shaft. – 0scar Sep 10 '20 at 11:53
  • Both the bore and shaft are 5.0 mm, a picture won't help much since there's no visual indication that it's offset, but when I measure thickness (from the bore to the outside) it is slightly different when I rotate the pulley (about 0.5 mm). I'll upload a video of the wobble in the question. – Beacon of Wierd Sep 10 '20 at 12:12
  • If the shaft isn't bent, you might just have bad quality pulleys. Try swap the Y-stepper with the X-stepper. +1 for adding the video! – 0scar Sep 10 '20 at 12:26
  • Might also be just the back plate that is misaligned... – Trish Sep 10 '20 at 12:35
  • @Trish Which back plate? Are you talking about the white part which the motor is mounted to? – Beacon of Wierd Sep 10 '20 at 12:48
  • @Trish If the stepper is misaligned on the X-Z idler block, then the pulley will not wobble, it would spin around a skew axis. – 0scar Sep 10 '20 at 12:54
  • no, I mean, the part is made by combining 3 parts: the socket (holding the setscrew), the axis shaft with the teeth, and a circular plate as a guidance. If the last plate is not perfect, it looks wobbling and isn't. – Trish Sep 10 '20 at 12:59
  • Ii was becoming a little too much for a comment, thus added it as an answer what I meant. – Trish Sep 10 '20 at 13:30
There are several possible causes for this. From least to worst:
  • The part itself is good, but the faceing cover plate is misaligned. No action needed.
  • The part is mounted in a way that makes it wobble, re-mounting helps.
  • The part is bad and needs to be replaced.
So, let's see the anatomy of a Timing Belt pulley. They exist in basically 3 general types in the McMaster Carr catalog: One flange, two flanges, no flanges. I am not affiliated with them, but they are pretty much one of the parts vendors in the industry that has almost everything, making them the convenience option. In the mantra, they are the "fast-good" option with the "everything" bonus and that the catalog of parts with 3D is integrated into fusion360. A similar supplier would be RS.
MXL pulleys, McMaster Carr Catalog The fitting part, one-flanged variant.
The part OP ordered is the "With One Flange" design, it is 6mm wide, 5mm axle and 16 teeth. The McMaster Carr catalog has two very close matches to OP's part: 3684N11 & 3684N12, about 6$ for a part machined from a solid piece. Why is that relevant?! well, the part OP ordered is not made from a solid piece but at least two parts: the body and one flange plate, as you can see on the product picture - the plate separation I marked with yellow here:
This is where the first error appears: if the flange isn't mounted centered (in poor quality it is rarely) then it appears to wobble but actually doesn't. But the video shows that the axis seems to be straight, while both the front and backside of the pulley wobble in the XY position. This means it is not just the flange that is mis-mounted on the part.
Now, error number 2 is misaligned mounting. In case the bore is good, you can often fix a misalignment by removing the part and mounting it again, more carefully, possibly using some thin shim metal around the axis. In some cases there is a pair of screws already to do this, if not it can help to modify the part with one or two extra alignment screws, allowing to sift the gear's center a slight bit by tensioning the additional screws.
In the case of OP's linked part, the screw that is not radial but protrudes next to the axis is designed to come over the flat of the axis and the other one is to tighten it down.
If the bore for the axis however is really skewed, and even after repeated re-mounting or shimming nothing can be done, a new part is needed. With the measurements of the part, you can order at a lot of online catalogs, the price and quality differ greatly. However, the engineering mantra strikes:
Cheap, Fast, Good. Choose two.
