I have an old air conditioner and most of the vent flaps/louvres are missing. I've modelled it in Solidworks, but can it be printed? Are the tips too small for 3D printers? It's about 14 cm long end-to-end.
Here's the drawing sheet (dimensions are in mm):
Air conditioner Louvre door
John M.
  • 111
    What 3d printer do you have? What is the smallest sizes? What filament are you using? – marcellothearcane Feb 24 '20 at 12:45
  • @marcellothearcane I'll be taking it in my local library and they've got a UPBox using ABS. I've just added the drawing sheet in the OP. – John M. Feb 24 '20 at 15:57
  • Hi @JohnM. Almost anything can be printed with enough support material. Are you asking for a design review and an analysis of the best printing plan? It really isn't possible to answer this question in a way that would be helpful without more information about your goals and constraints. – cmm Feb 25 '20 at 14:31
Dimension-wise it's probably ok.
If you want to print it as a single piece it would be quite challenging because of the cylinders, overhangs and bridges present in multiple directions: overhangs and bridges result in lower quality and precision, while cylinders can be printed nicely only when their axis is vertical.
However I see that you could easily split the component into multiple parts, each one of which could be printed optimally.
You can glue the different parts together and you are done, see What glues for PLA? and What glues to use for PETG?
FarO
  • 3,906
    This could be printed with minimal supports if printed standing slightly canted by around 30° on the right side in the picture. – towe Feb 24 '20 at 13:14
  • Interesting. I'll split the part into 3. I suppose the cylinders should face up when printing? – John M. Feb 24 '20 at 17:03
    Into 3 parts? Why not split it in half then you get 2 half Louvre doors of about 2.5 mm thick which you can glue together. ABS might be challenging to print it upright or slanted under 30 degrees. PLA/PETG is less prone to warping, I would prefer that over ABS. – 0scar Feb 24 '20 at 17:49
    Printing in two parts seems a good solution to me – FarO Feb 24 '20 at 17:54
    Printing it cut in 2 parts upright also allows to directly access the internal area through the "center" cut, and insert a stiffening piece of metal along the whole length. – Trish Feb 24 '20 at 19:27
