While trying to figure out if I should start 3D printing with FDM (Creality Ender 3) or with SLA (Elegoo Mars), I got hooked on the bonus feature of attaching a laser upgrade on the 3d printer to make paper cutouts and cards. I read that its quite easy for the Ender 3 and dozens of other FDM printer, but I could not find anything about adding a laser to resin printers.
Question: Is it possible at all to attach a laser engraving module to a SLA 3D Printer like it can be done to FDM?
Additional information about pro/cons regarding this topic would be nice and are truly welcome.
user19928
Not with consumer equipment.
FDM printers are functionally three-axis motion control machines: "extrude quantity W material at position X Y Z, continue to next W, X, Y, and Z."
Adapting it to control a laser position is a relatively simple task, because most of the logic is the same. "fire laser for W duration" instead of "extrude quantity W material". Moving the laser around is functionally similar to moving the print head around.
Consumer SLA (aka "DLP" or "mSLA") is an entirely different logic, a different process. It is effectively layer-by-layer snapshots, rather than multi-axis motion control. They do a whole layer at a time, then lift the whole object up for the next layer: "flash layer 1 for W duration, lift bed Z, proceed to layer 2."
Professional/industrial SLA printers that use lasers exist (like SLS), but they're tuned to precisely cure photopolymer resins, not cut things.
T.J.L.
  • 158
