The last version of Ultimaker Cura that supported 32-bit Operation Systems was Cura 2.3.1 of 2016, which of course has a lot of items not yet in it and doesn't fit the demand of offering some update at worst from 2018.
32-bit support is starting to fade from the support of projects, as 64-bit makes a lot of things much easier and faster and 32 Bit Windows likewise is pretty much a dead-end branch with Windows 7 Support being discontinued on January 14th, 2020. For example, the Slicer project says on their documentation of the May 2019 4.10 version: "We do not make 32 bit builds available."
Yet there is rescue with the Slic3r-Family!
Slic3r 1.3.0 is open source, available as 32 and 64-bit versions, and was released in November 2018, making it somewhat up to date. You need to customize a lot of settings in it, but it is after all quite a powerful slicer - for which you have to write your own Start Code, define your filament settings and machine.
Repetier Host 2.1.6 is likewise a 32-bit application. It's technically a console with slicing features and uses one of several engines to slice - including the Slic3r and Slic3r Prusa Edition engines, which run on 32-bit. In comparison to Slic3r, I find its UI for placing items a little more user-friendly. It does pull the settings from Slic3r, if you have that installed.
Slic3r Prusa Edition/PrusaSlicer is a derivate of the Slic3r project. 2.2.9 was released in December 2019. It too runs on 32 bit systems. It is, UI-wise, even more comfortable than Repetier Host and is somewhat similar to Ultimaker Cura 4.
