Flashed Marlin 2.0 on my Folgertech 2020 Prusa i3 variant.
Calibrating seems to have gone smoothly until I tried to set up UBL.
Saved the mesh into EEPROM with the M500 command after a G29 P1.
When trying to do a test print with G26 P10, the temperatures for bed and hotend seem to jump (see this video).
Not sure if this helps but I was following this tutorial.
Not sure what's going on here or how I can fix this. When I power cycle everything, this issue persists.
I noticed my Z probe arm's servo was buzzing. I unplugged it and the numbers stabilized. Not sure what's going on but seems like I need to stop the power going to the servo when it's back to the 0 degree position.
PGT
  • 201
    Hi PGT, welcome to 3DPrinting.SE! Your last edit sounds like an answer, but maybe not the preferred solution... Please add a photo, from the edit we got some idea of the ABL leveling system you are using. – 0scar Nov 19 '19 at 07:04
  • Hi @0scar, thanks for the response. Definitely not ideal since I want the servo to be locked in place when doing the Z-axis homing, my current solution (I will test when I get home) is to turn off the power of the servo when it gets to a specific angle. If it's not locked in place, then it might move when doing the bed levelling. Can I ask what should be in the photo? – PGT Nov 19 '19 at 16:24
  • I meant a photo of the Z-probe on the hotend carriage. – 0scar Nov 20 '19 at 05:49
