I need help opening a .max file a friend sent me. The thing is, I don't have Alias Maya. Well, a copy of Alias Maya that works anyway.
Are there any other file openers that I can use? Or do I have to get Maya to open the file? Would Alias Maya open the file? I don't want to get download 1.3 GB and discover that there is 15 MB file opener.
Is there a file converter maybe? That converts .max to, maybe, .obj?
GipsyD
  • 423
  • I believe the best tool for such conversion is 3DMax itself. I also tried [google](https://www.google.com/search?q=convert+max+to+stl) which returned me some worth-to-check results. – darth pixel May 10 '16 at 04:27
  • If you want to use it for 3d printing then I suggest you to ask your friend to export it to STL format. – Sergei Krivonos May 11 '16 at 08:13
You could try import it with blender. It's a free software which should be able to import the files.
First thing is to go the the File->User Preferences->Add Ons tab. In the Import-Export section, enable the 3DS Add-on.
After that you can export it to the desired format. Before exporting you must select the model/mesh you want to export. Otherwise nothing will be exported. The obj exporter is enabled by default in blender.
