Often, the pre-generated G-code is enough for start and end. However, sometimes we want to have something different. In this case: how to generate an audible alert of something like 4 bleeps at the end of the print, after putting the printer into the end position and when the bed has reached a "safe" 30 °C?
Asked
Active
Viewed 2,372 times
Let's put the parts one by one:
- Wait for bed temperature being at 30 °C:
M190 R30 - Play Bleep for 1/5th of a second:
M300 S440 P200 - Wait for 1/5th of a second:
G4 P200
That gives:
M190 R30
M140 S0
M300 S440 P200
G4 P200
M300 S440 P200
G4 P200
M300 S440 P200
G4 P200
M300 S440 P200
G4 P200
Just for 0scar:
M300 S1396.91 P400 ;f7
G4 P400
M300 S1661.22 P600 ;as7
M300 S1396.91 P200 ;f7
M300 S1864.66 P400 ;b7
M300 S1244.51 P400 ;es7
G4 P400
M300 S2093.00 P400 ;c8
M300 S2217.46 P400 ;des8
M300 S1661.22 P400 ;as7
M300 S2793.83 P400 ;f8
M300 S1244.51 P200 ;es7
M300 S1046.50 P400 ;c7
M300 S1567.98 P400 ;g7
M300 S1396.91 P1600 ;f7
- 43
- 92
1Cool, I'll implement it as soon as you post how to play [this](https://www.youtube.com/watch?v=Qx2gvHjNhQ0)! ;) – 0scar Sep 23 '19 at 04:53
2@0scar There you go. Beverly Hills cop. – Trish Jan 13 '20 at 21:37
Lol! I will give it a try! – 0scar Jan 13 '20 at 22:01
Trish's version is good but wait for bed temperature being at 30 °C (M190 R30) before setting the temperature to 0 °C (M140 S0)
So this is my version:
G91 ;relative positioning
G1 E-1 F300 ;retract the filament a bit before lifting the nozzle, to release some of the pressure
G1 Z+0.5 E-5 X-20 Y-20 F9000 ;move Z up a bit and retract filament even more
G28 X0 Y0 ;move X/Y to min endstops, so the head is out of the way
G1 Y150 F5000 ;move completed part out
M84 ;steppers off
G90 ;absolute positioning
M190 R30 ;waits until cooling to 30 °C
M300 S300 P1000 ;beep
M104 S0 ;extruder heater off
M140 S0 ;heated bed heater off
jæk
- 51
- 5
ups yeah my bad..I was talking about the M190 R30 gcode but - hey - you used the "R" right so my fault..I'm gonna edit my answer – jæk Oct 04 '19 at 14:34
Yur order of commands in the revamped... You do realize that you set the bed off (M140 S0) and then demand the printer to target 30°C after that and not turn off the bed again? – Trish Oct 05 '19 at 15:23
