I want to print a model that I acquired in the LiDAR file format LAS.
I don't have a printer but I'm planning to send a model to one of those shops who print for you.
What do I need to do beforehand to make it print OK?
The dude
  • 133
  • Could you please provide a source for the LAS format you mentioned? Perhaps the name of the program that produces it, so people in the future can understand where a LAS file comes from? – tbm0115 Mar 26 '16 at 17:04
Because my research shows that LAS files are point cloud data, you would first have to convert the point cloud to a mesh. Point clouds are just that, data references to points in 3d space. A printing service works with files that represent planar surfaces, properly joined (watertight, aka manifold) to form a solid or solid surface model.
The only resource I was able to find involves using Meshlab. There are two reasonably practical references for this process.
The first is somewhat generic and provides the conceptual information: Point Clouds to Mesh
The second appears to be a more step-by-step method:
Point Clouds to Mesh (2)
I would expect that if you are successful in creating a mesh from your data, you would then want to use a program suitable to determine (and repair) any non-manifold portions of the model. There are many available, including Meshmixer, although the others have escaped my alleged mind at this moment.
