My model layers are printing much as I expect but the parts when removed from the plate are very soft and flexible and fail to harden any further in sunlight or UV lamplight. A tall or slender part will bend and distort under its own weight while printing. I am using LCD-T resin, I have increased time and reduced thicknesses and am now using 0.04 mm layers at 20 s and 255 brightness with no improvement. Can anyone suggest what I need to change?
Asked
Active
Viewed 285 times
4Could it be something wrong with the raw resin? How are you storing it (temperature and lighting conditions)? How old is it? – Dan Hulme Feb 21 '19 at 16:35
can you run a hard-test of the resin by pouring a tiny sample onto a glass surface and leave it out in the sun? Don't tough it though – Trish Feb 21 '19 at 21:39
This has nothing to do with post-processing. If the part is sagging in the chamber (or when removed from the plate), then the cure-time per layer (illumination time) is probably set too short. – Carl Witthoft Feb 22 '19 at 14:25
Thank you folks. The issue was bad/old resin and left in the tank too long. Replacing all my stocks with fresh and following rigorous stirring and decanting I now have resin curing well during the print. Sorry to have taken so long to get back to it.
R.Powell
- 61
- 3
