I made a test print for a small gear (~ 1.5 inches in diameter) a few months ago, with a hole through the center. On the first try, the filament (ABS) fused to the print bed, meaning that I had to spend ten minutes scraping off material to loosen it. One solution to this is to use painter's tape spread across the print bed.
This yielded a good print during the next run. The problem with this method was that some of the tape subsequently fused to the backside of the gear; it was so tight that I had to discard the prototype. Multiple varieties of tape made no difference.
Is there a way to continue using this tape without having it fuse to the filament?
