I am trying to figure out some calculations regarding stepper motor and lead screw.
These are the things need answer:
  1. Selection stepper motor to lift given weight?
  2. Amount of load threaded rod can handle?
I found a this topic how much weight can my stepping motor lift?
Equation
where,
  • p = pitch of the screw
  • Se = screw efficiency = Standard lead screw will be between 20% (.2) and 40% (.4)
  • Sf = static force. This is the force that is needed to start the movement. The number may be eliminated, but it is good to use a number in the 5 N to 20 N range.
  • Load = the expected load that the effort will need to carry (i.e., the router and the included axis assembly that the motor will need to lift)
  • R = radius of the lead screw
Based on this equation with following data
  • Load: 5 Kg = ~25 N
  • Thread rod specs;
    • Pitch : 1.25 mm = 0.0492126
    • Dia : 8 mm = 0.314961 inch
  • Motor :
Calculated Effort = 6.22 N = 1.4 lbf = 22.4 ounce
Radius = 8 mm = 0.315 inch (using Pitch conversion table)
So torque = 22.4 * 0.315 = 7.056 oz-in = 0.0498 Nm
As per data sheet Motor can provide an Axial force of 10 N. I'm using two of such motors, so this motor is enough
However, based on this calculator, Lead Screw Torque and Force Calculator, with following information:
Torque required to raise in 0.0252 Nm.
  • Which should be used for calculations?
  • How to find the running torque of stepper motor?
  • I know it will be less that Holding torque, but what percentage?
Nema 17 that I've given Holding torque is 5.5 Kgcm or 0.55 Nm. My second calculation gives the calculated torque to lift is 0.0252 Nm.
Also from this Threaded rod load table, load capacity of 8 mm rod is somewhat around 270 Kg.
Looking for further inputs.
Athul
  • 653
  • 14
  • 5 kg is about 50 N, maybe change `Load: 5 Kg = ~25 N` to `Load: 5 Kg ~ 50 N => 25 N per stepper` – 0scar Dec 18 '18 at 15:23
    Possible duplicate of [Ball screw: Maintaining Z axis position when motor is OFF](https://3dprinting.stackexchange.com/questions/6949/ball-screw-maintaining-z-axis-position-when-motor-is-off) - Same problem, different values – Trish Dec 18 '18 at 20:23
This is a work in progress - I'm still plugging in the numbers
A couple of issues:
  • You appear to be mixing Force (effort) and Inertia and comparing them directly - this mistake seems to have come from the first link;
  • You used 8 mm diameter, instead of 4 mm radius, to calculate the torque
  • You haven't calculated the holding force, which would provide the holding torque required, which can be easily compared against the specification of the stepper motor;
  • I can't see where you obtained the value for axial force of 10 N, from the datasheet of the stepper motor.
Regardless of these issues, tackling each question separately:
First equation
Your first equation, for effort, is
$$F_{effort} = S_f+\frac{Load}{2*\pi*\left(\frac{R}{P}\right)*S_e}$$
where,
  • Starting Force, from linked article, worst case scenario, $S_f = 20$ N
  • Radius $R=4$ mm$=0.004$ m
  • Pitch $P=1.25$ mm$=0.0125$ m, and
  • Screw Efficiency, from linked article, worst case scenario 20 %, $S_e=20=0.2$
So filling in the numbers, for 25 N:
$$effort = 20+\frac{25}{2*\pi*\left(\frac{0.004}{0.00125}\right)*0.2}$$ $$effort = 26.22$$
It is worth noting that this running torque only comes to 6.22 N, much smaller than the worse case value of the starting force, of 20 N:
$$\frac{25}{2*\pi*\left(\frac{0.004}{0.00125}\right)*0.2}$$ $$ = 6.22$$
and plugging in the numbers, for 50 N:
$$effort = 20+\frac{50}{2*\pi*\left(\frac{0.004}{0.00125}\right)*0.2}$$ $$effort = 32.44$$
Again, it is worth noting that this running torque only comes to 12.44 N, much smaller than the worse case value of the starting force, of 20 N:
$$\frac{50}{2*\pi*\left(\frac{0.004}{0.00125}\right)*0.2}$$ $$ = 12.44$$
It should be noted that these values are for a force, in N, not torque, in N•m, and I can't see on the datasheet were you obtained an Axial force of 10 N. To convert these to a torque, you must multiply by the radius of the M8 x 1.25 spindle - M8 is 8 mm, therefore the radius is 4 mm, which is 0.004 m:
$$T_{raise} = F_{effort} \times 0.004$$
Thus reducing the values for the Torque (derived from the effort) even further, by a couple of orders of magnitude, to 0.104 and 0.12976 N•m, for loads of 25 N and 50 N respectively.
So, the estimated value of worst case starting force would appear to be the dominant factor in selecting the stepper motor.
Regardless of all this, if, as you say, that the holding torque, $T_H$, is higher than the running torque, $T_{raise}$, then the holding torque would be the deciding factor in selecting a stepper and the running torque can be discounted.
It is unclear whether the equation that you found is the appropriate equation for calculating the holding torque. This equation appears to be for moving the load, whereas you need it for merely holding the load. For completeness both the holding and lowering torque values should be calculated.
Second equation
Your second equation apparently from Wikipedia - Force, via Lead Screw Torque and Force Calculator,
$$Torque_{raise} = F*D_m/2*\frac{L+\mu*\pi*D_m}{\pi*D_m-\mu*L}$$
where,
  • Force, $F$
  • Diameter, $D_m$
  • Pitch distance of square thread, $L=\frac{1}{D_{Thread}}$, where $D_{Thread}$ is the thread density given in the table.
  • Coefficient of friction, $\mu$
Whilst I can not see that equation on Wikipedia's Force page, I did manage to find the equation for raising, and the equation for lowering, on the Wikipedia page for Leadscrews - Mechanics1:
$$T_R = \frac{Fd_m}{2}\left(\frac{l+\pi\mu{d_m}}{\pi{d_m}-\mu{l}}\right)$$
and
$$T_L = \frac{Fd_m}{2}\left(\frac{\pi\mu{d_m}-l}{\pi{d_m}+\mu{l}}\right)$$
Plugging in the numbers for 50 N of load:
$$T_R = \frac{50\times0.007375}{2}\left(\frac{0.00125+\pi\times 0.25\times0.007375}{\pi\times0.007375-0.25\times0.00125}\right)$$ $$T_R = 0.1848 \times 0.308$$ $$T_R = 0.0568$$
$$T_L = \frac{50\times0.007375}{2}\left(\frac{\pi\times 0.25\times0.007375- 0.00125}{\pi\times0.007375+0.25\times0.00125}\right)$$ $$T_L = 0.1848 \times 0.193$$ $$T_L = 0.0357$$
NOTE: As the link to the calculator states, there are two different torques - one to raise, $T_R$, and one to lower, $T_L$. As the lowering torque, $T_L$, is less than the raising torque, $T_R$, then it isn't really necessary to calculate it, or consider it when selecting the stepper, as the raising torque is the dominant factor.
Again, if, as you say, that the holding torque, $T_H$, is higher than the running torque i.e. $T_R$, then the holding torque would be the deciding factor in selecting a stepper and the running toque can be discounted.
This would appear to be much simpler to answer, as a value is given in the specifications for the rod, depending upon what you actually mean. It could be:
  • The weight that the rod can support before slipping, or;
  • The weight that the rod can support before slipping before mechanical failure,
I would imagine that, the specification given is the weight supported before the threads give way and break.
Footnotes
1 These equations only account for the friction of the thread and the term for the collar appears to have been omitted.
From Torque Required to Raise Load (TR) Calculation, the full equation, for both thread and collar, is given by:
$$T_R = \frac{Fd_m}{2}\left(\frac{l+\pi\mu{d_m}}{\pi{d_m}-\mu{l}}\right)+\left(\frac{F\mu_cd_c}{2}\right)$$
where,
  • Torque required to raise load, $T_R$
  • Load, $F=50$ N
  • Mean diameter of square thread, $d_m = X?$ m
  • Mean diameter of collar, $d_c = X?$ m
  • Pitch distance of square thread, $l = 0.00125$ m
  • Coefficient of friction for thread, taken from the Solved Example, $\mu = 0.25$
  • Coefficient of friction of collar, taken from the Solved Example, $\mu_c = 0.25$
As the mean diameter, $d_m$ is not provided, it can be determined from the pitch, $l$, and nominal diameter, $d_n = 8$ mm, by
$$d_m = d_n-\frac{l}{2}$$ $$d_m = 0.008 -\frac{0.00125}{2}$$ $$d_m = 0.007375$$
The mean diameter of collar, $d_c$ is not given...
$$T_R = \frac{50\times0.007375}{2}\left(\frac{0.00125+\pi\times 0.25\times0.007375}{\pi\times0.007375-0.25\times0.00125}\right)+\left(\frac{50\times0.25\times{d_c}}{2}\right)$$ $$T_R = 0.1848 \times 0.308+\left(6.25\times{d_c}\right)$$ $$T_R = 0.0568+\left(6.25\times{d_c}\right)$$
    You made a mistake. Pitch is 0.00125 – Vaidotas Rastenis May 19 '19 at 22:48
  • Hi @VaidotasRastenis and welcome to SE.3DP. Ah yes, so I did...many thanks... I'll convert your answer to a comment to my answer. Thank you again. :-) Also the radius of the spindle should be 0.004, not 0.04. Fortunately, that means the answers to the first equation remain the same. The result to second equation changes though. – Greenonline May 19 '19 at 23:09
  • oldy but goldie - still WIP? – Trish Jun 08 '20 at 19:00
  • @Trish - ah yes, wow, I'd forgotten all about this. Hmm, I wish I'd never attempted to answer it... it's a nightmare of a question... lol. Would you like to finish it off for me? :-) – Greenonline Aug 03 '20 at 10:15
