I need to replace this stepper motor with the following product identification:
Y-axis stepper for the CR10-S5
It’s a Y-axis for CR10-S5 and labeled as JD42HS60-1500A-02F. What type of stepper motor is this?
Peter Lee
  • Hi Peter, and welcome to 3D Printing.SE! – 0scar Dec 18 '18 at 07:04
  • I have found the motor in Ebay, check the following link: https://www.ebay.com/itm/Creality-3D-Two-Phase-42-60-RepRap-60mm-Y-axis-Stepper-Motor-For-CR-10-400-500-3/163335682211?hash=item260790b8a3:g:lE0AAOSwlxxb0kqd – Raul Moreno Jul 13 '19 at 18:10
This is a NEMA 17 motor. It is virtually identical to the NEMA 17 motors Creality uses in most of their 12V products.
In contrast to other companies, Creality uses a different connector with a flat ribbon cable instead of color-coded wires.
The upper line of the label identifies it more clearly:
  • JD Identifies the factory/manufacturer
  • 42 identifies the faceplate size as 42mm square, so a NEMA17
  • HS identifies how the holes are shaped
  • 60 is the height of the motor as 60 mm.
  • 1500 identifies how much power is OK for it, here: 1500mA = 1.5A
  • A specifies our motor has a maximum safe temperature of 104°C
  • - gives us no voltage for this motor, but as you have a CR10, it should be 12V
  • 02F is supposed to tell us something about the wiring and steps per rotation, but I can't find out what.
Side Note: the Creality Ender3 uses 34mm high stepper motors.
  • Would a voltage rating be relevant ("gives us no voltage for this motor")? I thought that for magnetism it is the current which matters. – Andrew Morton Aug 09 '20 at 18:58
  • @Andrew, yes current matters in magnetism. Any voltage specified on the datasheets is "Tested at" voltages. – user77232 Aug 09 '20 at 20:35
  • @AndrewMorton operation voltage *does* matter. If you run a machine designed for 12V with 24V you burn it out. If you run it at 6V, you might not operate it at all. – Trish Aug 10 '20 at 08:36
