I was noticing on a print I had just done that the quality was not up to typical snuff. I had just started using a roll of PLA filament that I had been keeping on a shelf without a wrapper for a couple months. How long can you store filament before it gets too hydrated from the air to print? I expected more than a couple months but perhaps I am wrong?
2Welcome to 3DPrinting.SE! What type of filament are you talking about (ie: PLA, ABS, etc.)? Each filament is going to be different. Was the filament left open to the air or did you have it contained somehow? – Pᴀᴜʟsᴛᴇʀ2 Nov 26 '18 at 16:47
Different filaments have different (sometimes extreme) requirements, especially for humidity. Please specify what materials you are talking about. – Davo Nov 26 '18 at 17:59
Sounds like a duplicate of : https://3dprinting.stackexchange.com/questions/6982/which-filaments-actually-do-need-to-be-stored-in-a-drybox – user77232 Nov 27 '18 at 21:07
@user77232 That particular question asks about **which** types need to be stored, this question is **how long** you store it outside the container until it is affected by moisture. It is just a subtle difference though :) – 0scar Nov 29 '18 at 12:28
In theory, most filaments don't go bad within a year. However, praxis shows, that averse conditions can impact the filaments over time and age them to unusability.
Among the damaging factors is heat, but most filaments also are hygroscopic and absorb water to some small degree, or even heavily like Nylon.
As a result, it always a good idea to at least try to store filament dry. To enforce this, some use racks in a well-heated room, others are blessed with very dry weather overall. And on some locations, like the coast, you might even be forced to use dryboxes for each and every filament to try to slow the degradation of steady hot humid air leaching out the additions from the filament.
Dryboxes can keep the filament reasonably isolated from the surrounding air and so prevent moisture interacting with them to some degree. It is also a good idea to store them out of direct sunlight, as UV light might destroy color and/or the plastic. More information on why to use them is for example at this question
A couple construction videos using an IKEA box and a bit of foam were offered by Tom (Thomas Sanladerer) and CNC Kitchen (Stefan Hermann) in 2017.
But fear not: most filaments - PLA included - can be freshened up again if the damage is not to prolonged! Baking them at a low temperature or storing them in a dehumidifier has worked in some climates. For PLA, keep the temperature at below 80°C. A couple of hours should get some the moisture that has seeped in out again. The Quality might not get back to that of fresh filament in all cases, but you might at least regain reasonable to good printability.
Also note, that different filaments are differently affected. ABS for example is a little less hygroscopic than PLA, while HIPS is one of the least hygroscopic filaments available.
- 20,169
- 43
- 92
It depends on the filament, the shipping and the local conditions. I'm on an Island, so very high humidity.
We have several useless spools that never worked out of the box. They were shipped seafreight from China and had a couple of months journey. Only 2 spools out of 10 were useable.
With other filament seafreighted from Australia for 3 weeks filament here seems to last about a month at best, with 4 days being the lower limit so far. This is despite being kept in an airconditioned room most of the time.
We have had limited success with drying them out.
- 1,207
- 11
1PLA or something different? It might possivbly be easier to swap to ABS, even if that is smelly - ABS is to my knowledge less hygroscopic. – Trish Jul 12 '22 at 12:51
@Trish the Chinese shipment was both PLA and ABS, the other was just PLA. Waiting on PETG right now with fingers crossed. – Kilisi Jul 12 '22 at 13:03
were the 2 good spools PLA or ABS? PETG is also hygroscopic, somewhere between ABS and HIPS as my sources tell me. – Trish Jul 12 '22 at 13:16
One good PLA and one ABS, but thinking about it, there is an unopened ABS somewhere as well. We're airfreighting the PETG, so hopefully it works out for us, postage is more than the filament though. – Kilisi Jul 12 '22 at 13:23
I suggest trying to test the ABS, and if one spool is still good, dedicate any yet unopened to "emergency stocks", maybe the rolls are still good. Airfreight... you might want to check the seal of the bags. – Trish Jul 12 '22 at 13:28
@Trish Not terribly worried about it. Last shipment was ok for a few weeks. Thats all we need, as soon as a roll is opened we'll pump through it. I only know the filament goes bad because I tried printing the odds and ends of filament when I ran out of PLA. – Kilisi Jul 12 '22 at 13:31
Generally, as long as the bag is well sealed, it is often good, unless it was manufactured badly. But if you go through a roll within a fortnight, and that's your "shelflife" of an open spool due to conditions, it's somewhat good. Have you ever tried to vacuum-seal an opened spool? That might prolong shelflife too. IIRC you have high humidity, high-temperature tropical conditions year-round, yes? That is among the hardest conditions I can think of aside from dedicated destructive lab testing. – Trish Jul 12 '22 at 13:38
@Trish na, don't want to get complicated, we're just going to print full on once a roll is opened. – Kilisi Jul 12 '22 at 13:41
1Usually the best way anyway, but for specialty materials. I printed TPU recently, but not the whole spool, and the next time I will use that is at least months away (the school that I made the parts for is in holidays), so I am actually storing it in a bag in a box to try and keep it as fresh as I can, though climate here is not as deadly to filament – Trish Jul 12 '22 at 13:59
The answer is that it depends on the climate you are in or the climate in your house. The more humid, and the higher the temperature, the faster the moisture is taken up in the filament (note also that 40 % RH on a warm day has much more moisture in the air than 60 % RH on a cold day).
I have obtained a spool of filament that has been left in the garage for a few months, this spool has taken up so much moisture that it has become very brittle (unspooling will break the filament). Note that once the filament has taken up moisture, you could de-hydrate it, but it will never reach the same properties anymore as the moisture will change the molecules (shorten them), once broken they will not fuse by hydrating. It will however get rid of the water content so that there will be no steam bubbles when you print the filament.
Note that there are many types and brands of PLA, each with their own formula. The quality of the PLA has improved much over the years, implying that the moisture intake also depends on the brand and time of purchase. It is therefore very difficult to answer your question with a specific time frame, it could be months, but it could also be a week.
My largest printer is located in a room where occasionally laundry is being dried, and although there is only a little ventilation, the large spools of PETG do not take up the moisture of the laundry. Basically, the moisture saturation is also depending on the type of filament.- 32,029
- 59
- 135
To answer your question: it depends on the relative humidity. Generally, a few weeks in a semi-arid environment. But, it'll still print really well. If you're looking for really tight filament diameter tolerances, a week or even less could change the diameter .001 or more if there is moisture in the air. I've used PLA that has been exposed to air for a few months and it's been fine, but with small issues.
If the filament has absorbed too much moisture, you'll typically hear popping coming from the hot extruder as the water is burned off at the nozzle. Sometimes steam comes out of the nozzle when printing as well with "wet" filament. Usually, you can still get great results even if it has absorbed moisture. If the filament diameter has been affected significantly, (if it jams, or the water keeps the plastic too cool when it's coming off the nozzle) you can dry it out in an oven for a few hours like @trish suggested. I keep my filaments in a plastic bag with desiccant inside a big storage bin. Probably overkill but my water softener is in the same room and introduces moisture to the air, and my a/c blows right at the setup.
Dust is probably worse because it can accumulate much faster and cause jams.
source and reading
https://www.fusion3design.com/the-importance-of-properly-storing-your-3d-printing-filament/
- 31
