In the documentation of some commands of the Marlin firmware (like M112 - Emergency Stop), it says that the EMERGENCY_PARSER should be enabled to execute them instantaneously.
The thing is, I didn't find any information there of how to enable that EMERGENCY_PARSER or how it works.
Any help will be appreciated.
fsinisi90
  • 185
The constant EMERGENCY_PARSER is located in the advanced printer configuration file Marlin/Configuration_adv.h:
// Enable an emergency-command parser to intercept certain commands as they
// enter the serial receive buffer, so they cannot be blocked.
// Currently handles M108, M112, M410
// Does not work on boards using AT90USB (USBCON) processors!
//#define EMERGENCY_PARSER
To enable the EMERGENCY_PARSER, you need to remove the // before #define EMERGENCY_PARSER and recompile the sources.
Normally your printer will execute a command until it is ready to accept a next instruction. Without the EMERGENCY_PARSER set, the printer finishes the instruction that it is executing at the moment, if set, the execution is interrupted and immediately sent and thus not waiting for a clear space in the buffer.
  • Is there a way to know if `EMERGENCY_PARSER` is set without looking at the printer configuration file (for example, sending a command or checking the first responses when you connect via serial port)? Was this feature added on Marlin 1.1.0? – fsinisi90 Nov 23 '18 at 13:58
  • @fsinisi90 I don't know if you could try that out. You do need to somehow inject the `M112` in the midst of operation, usually that is done by the code as an emergency response on certain limit checks, I do not know how to insert that manually from outside. – 0scar Nov 23 '18 at 14:25
  • Well, I've already tried with `M190` (wait for bed temperature) and then `M108` and it's not working, but my firmware is Marlin 1.0.3 and I guess the `EMERGENCY_PARSER` was added on 1.1.0, so I don't even have the possibility to enable it. Anyway, I was looking for a way to check it on any printer from my source code (I'm connecting through pyserial), without human intervention. – fsinisi90 Nov 23 '18 at 14:57
