A z-axis homing issue is giving me an ulcer. I'm hoping someone can help with this.
As per usual, after the Z endstop is triggered on my TEVO Tarantula the gantry raises a bit then slowly lowers back down to the z=0 point established by the trigger. However, the gantry is now lowering well past the point triggered by the endstop. It's forcing the hotend to press down into the bed, and I need to reset the printer to avoid any damage.
I'm at a loss to understand why, and it's making re-leveling the bed impossible. Once I have the bed leveled, an auto home grinds the hotend into the bed.
I've done some cable management in the past couple of days but everything is connected where it should be. The endstops are responding, I've even manually triggered them so I know they're working, but the Z refuses to stop where it should.
I've printed at least once since organizing my cables but the bed wasn't level and then I noticed this issue when homing the Z for re-leveling.
For context, I've had several projects print successfully recently so things had been working fairly well. I haven't made any changes to the Marlin software since originally setting it up months ago. I had been poking around in some settings on the unit but I'm quite sure I reverted everything I tweaked. Regardless, I can't seem to find the menu I had accessed before, and I don't think I've ever had the TEVO successfully save any customizations made via the LCD interface anyway.
