Other than the most obvious issue with the filament kinking in the tube, what other issues could arise when trying to print flexibles (i.e. TPU/TPE, Nylon, etc.) with a Bowden style extruder setup?
Can the kinking issue be alleviated by a well-constrained filament path (proper ID) in a properly sized Bowden tube?
ifconfig
  • 851
  • 29
  • nylon is not a "flexible" filament in the sense, it is a somewhat flexible "hard" filament – Trish Oct 11 '18 at 06:25
As a user of an UM3E, which uses Bowden tubes and has TPU as an available material, I can tell you that the kinking issues can be alleviated or downright avoided.
I've printed quite a few things with the Ultimaker-brand TPU 95, and never had problems with kinking in the tube.
Ultimaker uses 2.85 mm filament, with Bowden tubes adapted for those and a rear motor, i.e. the motor is on the back on the printer and not right on top of the print head.
I personally wouldn't consider Nylon as one of the really flexible material, but that's my opinion. Never had kinking in the Bowden tube with Nylon either in my UM3E.
Sava
  • 504
  • 19
To also validate the first answer, I have been printing with TPU95A for a number of years and it has been one of the most reliable materials to use. The strength of the product alongside the flex makes it a test and production based outcome with fewer issues. My printer for the most part of this experience was the Ultimaker 2+ that has a similar set up to the UM3 with a more traditional hot end.
Cautions: Some older material profiles have the heatbed at 60c. I have always had better outcomes from room temp (no heat on the bed).
Brebinator
