I have an MKS Base 1.4 board with a TFT28 touch screen and a Titan Aero setup.
When I use the load filament command from the touch screen the motor turns at a crazy speed to load filament, whereas if I plug in my laptop and use Repetier host and send a load command it turns at a normal speed.
Is there a section in the Marlin firmware that allows me to set the actual extruding speed during load and unload?
MrPuffyNZ
  • 71
  • Please explain how you retract and unretract filament with Repetier Host. E.g. are you using the G10/G11 G-code commands? – 0scar Sep 04 '18 at 10:26
Loading and unloading filament through the LCD options is taking care of by G-code command M600. The options used when executing the M600 command define where the head goes and how much filament is extruded of which extruder. Apparently, there is a difference in calling the M600 command via the LCD menu or (un)loading filament through the Repetier application.
The Firmware-based and LCD-controlled retract options are defined in Marlin Firmware file Configuration_adv.cfg (Advanced Pause). The settings for Repetier are probably differently defined than in the advanced configuration file; you should look them up in Repetier. It could well be that separate G-codes (or scripts) are used for this. E.g. G10 is used to retract filament as set by M207 (both length and feed rate!). G-code G11 does the opposite, it unretracts the filament as specified by M208.
To answer your question, yes, you need to alter the values of the constants in Configuration_adv.h for changing the speed when using the LCD to change the filament:
// (mm/s) Unload filament feedrate. This can be pretty fast.
#define FILAMENT_CHANGE_UNLOAD_FEEDRATE     10
// (mm/s) Load filament feedrate. This can be pretty fast.
#define FILAMENT_CHANGE_FAST_LOAD_FEEDRATE   6
