I can not find anywhere default steps per unit for Makerbot replicaor 2. I'm using Ramp V1.4 instead original board and need to know default steps :/
Asked
Active
Viewed 2,414 times
The Replicator 2 and 2x use 18 tooth GT2 pulleys, 1/16 microstepping, and 200 steps/rev steppers. That makes the proper steps/mm value 88.888889.
Note that Makerbot used ~88.56 steps/mm in their defaults, which is the value you get if you calculate from the belt+pulley pitch diameter from the Gates GT2 specs. But this is the value you use for calculating belt length required in a closed loop, not for steps/mm. The 88.88... number is more accurate.
Ryan Carlyle
- 6,456
- 13
- 33
Hey once again, what about z axis then? – Anton Osadchy Mar 07 '16 at 17:47
Z is 400 steps/mm. (8mm lead, 1/16 microstepping, 200 steps/mm motor.) Sidenote, make sure you don't over-drive the Z stepper with plug-in drivers, it's only rated to about 0.4A. – Ryan Carlyle Mar 07 '16 at 19:15
@RyanCarlyle FYI minor typo above, you say 200 steps/mm for Z but I think you mean steps/rev since you already state Z is 400 steps/mm. Thank you for accurate numbers though! – guru_florida Aug 22 '20 at 15:12
