Context
A while ago I bought a kit for a 3D printer, along with filament etc. however, after some weeks I ran into some mechanical problems and because I had a lot of other things to do at the time I put the project on hold.
Now, almost a year later, I thought I would continue the project. I've got all the mechanical pieces back to work right now, but I have some questions concerning the filament.
Main question
Firstly, I have a nearly full roll of PLA still, but it has been left in a dusty attic for almost a year. I read here that it could still be used if baked for a couple of hours at 50 degrees Celsius. Does anyone have experience with this? Can this be done in my regular oven that I also use for food without risk?
Secondly, there is still some PLA stuck in the printhead. As this may have taken up moisture I fear it might expand and damage the printhead. Is this possible? How could I remove it?
dragonfly
  • 143
  • Hi and welcome to SE.3D Printing :-) This seems like there may be two *distinct* questions being asked here. If so, then it would be better, and preferable, to ask (and post) two separate questions. StackExchange rules state one question per post, else if can get a bit confusing to answer. Could you edit your question, remove one of the questions and ask it in a separate post? Thanks in advance. – Greenonline Jul 28 '18 at 02:07
Oven drying PLA
Heating filament below the transition temperature of the filament should not be unsafe when using that oven later for cooking food. You need the temperature to stay under the glass transition temperature of PLA so that the filament doesn't deform. Depending on the PLA filament, you should use the very lowest temperature your oven will be able to handle. Temperatures around 40 ℃ to 50 ℃ would be fine to leave the filament in for periods of 3 to 6 hours. Even at this temp your PLA will soften anyways at elevated temperatures, oven drying PLA not necessarily will give you good results. It is therefore of prime importance to store at least PLA (and nylon) in airtight containers with bags of desiccants.
Stuck PLA
Moisture will not travel that far into the hotend, so changes are minimal that expanding filament has already damaged your hotend. Just heat up the nozzle and push the filament in by hand, put off the heat and pull the filament out fast. Heat up again and insert some fresh filament. Note that moisture in filament breaks the large polymer molecules, so even after drying you are left with brittle filament. Personally this has caused few of my prints to fail as the filament string broke a couple of times during prints (just snapped before the Ultimaker 3 extruder feeder); this was experienced with 2.85 mm filament on small diameter spools (about 20 cm in diameter).
  • Another caveat about old filament: it may not be brittle but it can jam. I have a spool of PLA over a year old, stored it in an auto-rewinder drybox with dessicant that I periodically refresh. It worked fine for 1/2 the spool and 1/2 a year. It ISN'T brittle. Now it jams up the hotend after just a few layers. If I loosen the bondtech gears and manually push the filament down, it feels like compressing a spring (it springs back when I let go). After a clog comes out, it emerges sort of expanded as if there's water contamination. Baking is my next step. If that doesn't work I must discard it. – Anachronist Mar 09 '21 at 07:20
