I am building an enclosure for my 3D printer (Anycubic i3 Mega) and I'm wondering about heat and ventilation for my machine. My enclosure is is build from five 50x50x50 cm Plexiglass frames glued together. Currently I'm using only PLA for printing.
  • Does my enclosure need ventilation so my 3D printer would not overheat?
  • If yes, what type of ventilation?
    • Is only drilling holes enough? or
    • Do I need to add some ventilator?
  • If I would print with ABS in the future would it change the answer?
Sabriael
  • 143
When printing PLA you do not require an enclosure! PLA does not shrink as much as e.g. ABS. When printing PLA you should definitely ventilate your casing. I guess your steppers are also located in the enclosure, so you should be careful of not overheating the enclosure. Not only the steppers, but also think of the cold end cooling, too much heat in the enclosure means that the cold end cannot cool enough to prevent the filament to melt prematurely; this can lead to clogs. Also note that the printer electronics board may become too hot too (too hot stepper drivers will cause steppers to miss steps).
I once tried a towel over a Ultimaker 3 Extended to print a difficult filament to keep some heat in the enclosure; I encountered the above problems when I was young(er) and inexperienced :) We learn by trial and error some times!
However, ABS, requires control over the temperature during printing. Draft or uneven temperatures may lead to problems related to layer separation or heat bed separation. Many of the high-end box printers have doors available to enclose the front, this results in an enclosure with an open top (sometimes even for the top there are covers available). The heat of the bed then heats up the enclosure. A constant temperature of 45°C should not be too high to cause problems. When boxing it up completely, you could use a temperature sensor to monitor the enclosure temperature and schedule a fan to ventilate when it gets too hot.
    Since the most 3D printing filaments causes particals it is not a bad idea to enclosure the printer. Also to reduce noise and smell of bad filaments. – Horitsu Jun 17 '18 at 15:26
  • I am building enclosement mostly to keep dust, cat fur and my cat (although he doesn't seem to be much interested in my new instrument of destruction :)) away from printer also noise reduction is a thing for me. Thank you 0scar for your answer based on this I will add to my project fan and a temperature sensor. – Sabriael Jun 17 '18 at 17:58
