Im planning on building an enclosure for my CR-10S and am debating whether to use MDF walls lined with an insulation foam that reduces noise and keeps the heat in or going with double pane glass walls.
My main concern is not necessarily keeping the enclosure hot as it is for noise reduction. Obviously the wood with insulation will give better sounds dampening, but I am wondering if anyone has tried both or at least heard a printer before and after with both and if the glass alone had a significant effect on the sounds reduction.
