I need to add some simple image renders of STL files to a document. I currently open the STL files in Preview or one of the slicers and grab a screen shot.
Is there an easier or automatic way to generate PNG images from STL files on a Mac?
Mark Harrison
  • 1,043
  • 22
  • The answer below sounds pretty good, so I'll just comment that Google turns up a number of options for generating *postscript* files from STL, and you should be able to convert those to other image formats. I'm not sure how lossy that transition would be (and it'll vary by tool), but figured I'd mention it in case someone comes here looking for e.g. a non-Mac solution... – A C May 30 '18 at 02:31
If you have OpenSCAD installed, this shell script will generate 100x100 pixel PNG images for each STL file in your current directory.
for i in *.stl; do
  T=__tmp__$i
  b=`basename $i`
  echo import\(\"$i\"\)\; >$T
  /Applications/OpenSCAD.app/Contents/MacOS/OpenSCAD -o $b.png --imgsize=100,100 $T
  rm $T
done
Credit to 0scar for pointing out STL files can be imported into OpenSCAD.
Update: This code does the same, and generates an html file with annotated images of the files rendered. When I printed a batch of spare parts for my 3D printer I made a hardcopy and stuck it in the box so I could identify the parts later.
n=-1
H=00-catalog.html
echo >$H '<table>'
echo >>$H '  <tr>'
for i in $*; do
  n=`expr $n + 1`
  if test $n = 4; then
      n=0
      echo >>$H '  </tr>'
      echo >>$H '  <tr>'
  fi
  echo $i
  T=__tmp__$i
  B=`basename $i .stl`
  /Applications/OpenSCAD.app//Contents/MacOS/OpenSCAD -o $B.png --imgsize=200,200 $T
  echo >>$H
  echo >>$H '    <td>'$i'<br><img src="'$B'.png"></td>'
  rm $T
done
echo >>$H '  </tr>'
echo >>$H '</table>'
Mark Harrison
  • 1,043
  • 22
  • I've been trying to understand this code for a long time. What does the `echo import\(\"./$i\"\)\; > "$T"` line actually do? I'm trying to edit it so I can convert files that contain spaces in their names. – erdostamasa Nov 04 '21 at 18:14
    Note: If using in a headless environment like CI/CD/Github Actions, you will need an x11 environment. A workaround is to start a fake X11 with Xvfb e.g ( `Xvfb :99 & export DISPLAY=:99`) – spuder Dec 20 '21 at 05:57
  • @erdostamasa - the line is creating a one line temporary script that does an import of the STL file. When openscad is called, it imports this file then the `-o` and `--imgsize=100,100` from the command line do the rest. The `rm $T` then cleans up this temporary file. – Ken Hiatt Sep 11 '22 at 16:49
Typically you would install a (free) 3D model program as Fusion 360, FreeCAD, or many more options to choose from. Once installed, import the STL file and use menu options to export a picture of your STL.
Alternatively, if you have some programming skills, you could import the STL file in OpenSCAD and render and export a picture from there. Simply create an OpenSCAD file with the code line below and it will import your example.stl.
import("example.stl", convexity=10);
Through the menu you can then export the view to an image. Note that you can do that also from the command line as shown by the OP's own answer (nice example of command line usage of OpenSCAD).
These are not the only options, there are many more. E.g. this is a nice example. It also describes how Thingiverse.com does STL to web image.
  • For those looking for a nautilus thumbnailer using this technique, I've written a quick one here: https://github.com/sbrl/nautilus-thumbnailer-stl/ – starbeamrainbowlabs Aug 24 '21 at 15:16
If you don't mind using screen grabs, you could use AppleScript or whatever it's called in the latest MacOS versions to build an automated script to open each file, grab screen, save, etc.
Carl Witthoft
  • 3,008
You can use OpenSCAD, as stated in the accepted answer. Here is a version of that script that works for Windows for anyone who needs it, as I did.
# Change height and width to the desired output image dimensions, in pixels.
# The path to openscad.exe may also have to be adjusted based on your installation.
height=1080
width=1080
for i in *.stl; do
  T=__tmp__$i
  b=`basename "$i"`
  C:/'Program Files'/OpenSCAD/openscad.exe -o "$b".png --autocenter --viewall --imgsize=$width,$height "$T"
  rm "$T"
done
Paul
  • 111
  • What does the `echo import\(\"./$i\"\)\; > "$T"` line do? I'm trying to convert files with spaces in their names but keep getting various errors. – erdostamasa Nov 04 '21 at 18:15
