I am working on a design in OpenSCAD, and need (would want) two things that seem tedious to hand-code:
  1. A pattern of holes in a wall, for less weight/material. Could be round holes or some geometric pattern.
  2. Empty enclosed space, with some grid-structure for stability. Again, for saving weight/material (and time during the printing).
Are there any libraries for these things?
Tomas By
  • 509
  • 19
I'm not aware of libraries that do that for you (but you can create your own, see end of the answer), but creating a relieve hole pattern is not that difficult or tedious using iterator functions (e.g. the for loop). Note that it may not be a good idea to make enclosed holes inside your object, see the bottom section "Internal cavities in models" at the bottom of the answer.
Small OpenSCAD test script:
 tol=0.2;
 difference(){
   cube([100,100,10]);
   for (x=[10:20:90]){
     for (y=[10:20:90]){
       translate([x,y,-tol/2]){
         cylinder(r=9,h=10+tol,$fn=180);
This can be used for both parts of your question, but in case the pattern needs to be inside an object you need to lower the value of h in the subtracting cylinder and raise/translate it (you could use the center=true in the cylinder function as a parameter and raise the center to the middle of your object translate([x,y,objectThickness/2])). You could make a module of the recurring pattern yourself to create your library.
note: Replace cylinder with cube or any other geometrical solid or (2D) pattern (use linear_extrude) to subtract from your part.
Note that it is not always wise to create your own spacing/grid structure enclosed in the model. Please read the accepted answer of this question. This answer explains that slicer applications work best with true solids!
