I am currently printing the QTrainer aircraft from 3DLabPrint on my Anet A8, via the supplied i3-compatible gcode files.
So far, everything has printed fine, but the main undercarriage part tries to print off the left hand side of the bed by about 5mm.
I have tried manually adding an M206 X-10
line to the gcode file, just after G28 ; home all
, however this has not had any effect:
G90
M83
M106 S0
M140 S65
M190 S65
M104 S220 T0
M109 S220 T0
G28 ; home all
M206 X-10 ; added by me
G1 E-0.8000 F1800
G1 Z0.200 F1002
; layer 1, Z = 0.2
T0
; tool H0.200 W0.450
; skirt
G1 X9.382 Y10.533 F6000
G1 E0.8000 F540
G1 X10.536 Y10.537 E0.0388 F1440
However this does not work and I'm not clear on whether I am using this gcode command correctly, or whether my printer simply doesn't support that command.
Is there another way I can apply an X-offset to the gcode file (or printer) to move it a few cm to the right of the print area?
As I do not own Simplify3D and cannot currently afford it, re-slicing the STL files is unfortunately not an option.
Unfortunately there is no X-adjustment on the X limit switch (although I suppose I could temporarily tape something to the print head, so that it activates the switch sooner?).
My Anet A8 currently runs stock firmware, hooked up to OctoPrint and I have access to a Macintosh desktop computer.
