I'm attempting to model and print a globe. The semi-circular arm that holds the globe has an outer diameter of 98mm and inner diameter of 92mm, so the arm is fairly thin. The arm has a small hole on either end that fits around a protrusion at each pole of the globe to hold it in place. The hole extends into the arm only a few millimeters, so it doesn't go all the way through.
I printed the arm in ABS and it ended up being a bit too flexible to hold the globe securely. Obviously I could do things like making the arm thicker or extending the globe's protrusions all the way through the arm, but I'd prefer not to if I don't have to (you know, artistic integrity or whatever).
Would printing in PLA result in a more rigid part? I've tried to do some googling on this, but couldn't really find a definitive answer. Most comparisons focus on strength which I assume doesn't necessarily correlate to flexibility.
I'd also welcome any other suggestions for making the part more rigid.
