My Y-axis on my Monoprice maker select running ramps 1.4 and Marlin makes a thud noise when moving every now and then. I have noticed a 1 to 2 mm shift in the print when this occurs. I tighten the belts and alas no joy. I ordered new bearings which should be coming Monday. I also tried slowing the print down and still get the same result. Anyone have any ideas.
Asked
Active
Viewed 313 times
A thudding noise is usually a belt slipping through its end-restraints. A clicking noise is usually a stepper motor missing a step. Seized bearings could be the cause.
Mick
- 3,002
- 9
- 20
The issue was the X-axis top smooth rod came out. this caused the extruder to bang around and shift on the Y-axis when it shifted forward. thank everyone for their help.
- 59
- 135
user2698080
- 171
- 7
