20
I am printing a print using PLA on a Prusa i3 printer and an MK8 extruder, at 210 degrees celsius, 60 mm/sec, sliced with slic3r. The print consists of a base, with 4 tower-like projections that then join with a near-vertical overhang slope that isn't posing a problem for my printer.
However, even before the overhang begins, I am getting large amounts of strings as the extruder head jumps between the four towers in the print, leading to a "spiderweb" effect between them. How can I deal with these strings, and are they a warning that there might be something amiss with my printer, or possible other failures in other parts of the print?
nanofarad
  • 852
Stringing is often a result of too-high a temperature, or insufficient retraction. When there is highly liquid filament in the nozzle tip, it can adhere to the remainder of the print while dripping as the nozzle moves, leading to a thin string of the filament forming. As further travel moves are performed in each layer, this turns to a web.
The high temperature causes filament to be very liquid, causing it to move downward in the nozzle chamber easily, as opposed to having to be extruded forcefully due to viscosity. The temperature setpoint of 210 was high enough to cause this to happen.
A second possible cause, insufficient retraction, can also be blamed for this issue. Retraction is a process in which the extruder reverses its movement to pull filament back up the hotend, preventing it from dripping at the tip, and forming a string. Most slicers will allow specifying a numeric value in millimeters of filament to be retracted. Remember that printers with Bowden tubes between nozzle/hotend and extruder motor will require increased retraction and priming (extrusion when starting to print after a retract-and-move). Note that too much retraction can cause other problems, such as insufficient plastic in the hotend chamber at the start of the next printing move, which can cause gaps and other issues.
nanofarad
  • 852
Here's just a few of the things you might want to look into.
  • plastic - some plastic types are more stringy than others and there's also variation between brands and colors.
  • moisture in filament - water turning to steam tends to cause the extruder to ooze when it isn't printing, which can cause stringing.
  • temperature - too hot or too cold can cause stringiness.
  • retraction distance - not enough retraction can leave some nozzle pressure, causing it to ooze during travel moves (not sure how much retraction speed matters but I suspect it can make a difference too).
  • acceleration - if it's too slow it's more likely to draw out strings.
  • travel speed - faster travel speeds are more likely to prevent strings or make them thinner and less of a problem.
  • z-hop - raising the extruder on travel moves makes stringing more likely.
  • wipe - a longer wipe distance can be helpful to reduce stringing, especially with some of the more stringy filaments.
  • combing - avoiding passing over open spaces can reduce stringing in some cases
  • part cooling fan - more cooling might help to reduce stringiness.
There are other things too, the extruder design makes a big difference with longer bowden tubes being more challenging to tune. The order in which the layers are printed can make a difference too in some more specialized cases.
Gray
  • 105
walter
  • 688
