I've recently purchased Anet A8. First print went well, but now, the hot end temperature stays at ~230 °C. When I touch it, it is still cold. I tried the thermistor, and it correctly changes resistance when I blow on it (from 100 kΩ to ~70 kΩ). The voltage in connector is about 300 mV.
Does anybody know what could be wrong?
honza-kasik
  • 161
In my case, I had a bad resistor on my board. R41 had only 2.2 kΩ instead of 4.7. I replaced it and everything works now.
honza-kasik
  • 161
    Just out of interest, how did you know that the value of R41 was incorrect, and what the correct value should be? Did you deduce it from looking at a schematic, or comparing like components or by calculation? Or was it just a faulty resistor, that was the incorrect resistance when measured with a DMM? Was the incorrect part caused by a manufacturing or design error? – Greenonline Jul 16 '18 at 20:59
    I measured it with Ohmmeter and compared the result against value written on it. I really don't know how resistor may become 'bad'. Shortening maybe? – honza-kasik Jul 19 '18 at 12:02
  • It could have been badly soldered and over heated when the board was made; damaged in the fabrication process of the resistor itself, or; just got old? :-) **Note** that care should be taken when measuring components when on the board, rather than in isolation, as other components in parallel can change the actual reading. – Greenonline Jul 19 '18 at 12:07
