I've noticed that after my Anet A8 completes a print, the right hand Z mount ends up 1-2 mm lower than the left, even though I make sure both the left and right hand Z mounts of the X-axis are at the same height before switching on the printer.
Does anyone know what the cause of this might be?
I'm guessing something is causing the right hand Z to skip steps. I can't see or hear any obvious mechanical issues. I checked all guide and threaded rods were straight before assembly.
Could it be a faulty stepper or control electronics?
Andrew Ebling
  • 307
    Try reuploading a firmware of your choice ( I prefer Marlin SkyNet3D version because it is preconfigured for the Anet A8). – Tooniis Jun 09 '17 at 15:35
    Duplicate of the other z-axis questions. – Sean Houlihane Jun 09 '17 at 21:37
    Possible duplicate of [Alignment of dual Z-axis steppers](https://3dprinting.stackexchange.com/questions/3059/alignment-of-dual-z-axis-steppers) – Sean Houlihane Jun 09 '17 at 21:39
    @SeanHoulihane - Hmmm, I thought this sounded familiar, when I reviewed it. However, your question is about the *possibility* of out-of-sync happening, and the answer offers no solution to this OP's issue (apart from the "levelling"). This question is looking for *the cause*, and, I guess, a definitive solution. – Greenonline Jun 10 '17 at 04:18
  • This is one of the threads binding, due to bad alignment. Maybe I linked the wrong Q, there were 2 active when I experienced this. – Sean Houlihane Jun 10 '17 at 09:01
  • this one https://3dprinting.stackexchange.com/questions/3065 – Sean Houlihane Jun 10 '17 at 09:50
  • It does sound like a binding issue. Go into the control menu and manually drive the Z-axis up and down -- look for stickiness, 'bad' sounds, and so on. Make sure the tops of both Z screws aren't hitting anything. – Carl Witthoft Jun 12 '17 at 11:19
  • @Andrew Ebling, You have the Anet 8? I know its a little off topic but other than the issue you have how are you liking the printer? – Ljk2000 Oct 27 '17 at 14:21
  • @Ljk2000 with an upgraded 30A PSU, mosfets, re-soldered heat bed, drylin bearings and decent GT2 belts, it becomes a decent printer. I’m also looking at the AM8 metal frame upgrade. It’s good enough to get me hooked on 3D printing, for sure. – Andrew Ebling Oct 30 '17 at 17:15
  • @AndrewEbling With all those upgrades it sounds like you could have gotten a $200+ printer. I have heard some scary things about the power supply that comes with it though, Did the bearing improve the accuracy along with the GT2 belts? – Ljk2000 Oct 30 '17 at 17:54
My guess is your Z guides are not strictly parallel because there's no instruction how to install X guides correctly. When you install X guides, you can easily make horizontal distance between two Z-mounts either too small or too large, which puts extra stress on one of the Z motors. Move your extruder to home position, measure distance between bottom ends of Z threaded rods and between top ends, and try to adjust right Z-mount position on X guides so that these two distances become equal. Use hammer, but be accurate with plastic.
ZuOverture
  • 355
Try winding the Z axis all the up and down a few times using the front panel controls. Does it still go out of alignment? Is it out of alignment at the top? Does it come back into alignment when you wind it back down?
The principle is: if you have a dodgy motor drive chip, or a mechanical fault, it will skip some steps on the way up and the two motors will be out of synch. Then, on the way back down, it will skip an (approximately equal) number of steps and the motors will return to something resembling similar places.
KDM
  • 143
