Like many people, I have burnt the pins in the micro-controller connected to the E0 motor - the E0 motor is not working anymore and I need to print tomorrow! I need to control the extruder motor with the working E1 pins. How do I change this in firmware?
I tried to change to the pins in `pins_RAMPS.h" but it was a complete fail, the motors that i tried to change didn't move.
I have a Arduino Mega + Ramps 1.3 in "Extruder Fan Bed" configuration, I use Repetier-Host as host and Marlin as firmware.
Thomas S.
  • 903
masterleo
  • 153
    How did you find that Arduino pins were burnt? Have you tried spare motor driver? – Mikhail Z Dec 12 '16 at 18:30
  • @MikhailZ Yes definitely ! I swapt the drivers to test them, and I always replace the bad drivers with new/repaired ones. – masterleo Jan 25 '17 at 21:23
  • Changing pins_RAMPS should work. You must have done something wrong when trying it. – Tom van der Zanden Feb 10 '17 at 12:34
  • To elaborate on [this answer](https://3dprinting.stackexchange.com/a/3183/5740) of Thomas S, a more detailed description of swapping the pins is found in [this](https://3dprinting.stackexchange.com/a/5844/5740) 3D.SE answer. Please vote and accept an answer (we want this community to get out of Beta stage), thanks! – 0scar Aug 03 '18 at 19:15
I would change the pin assignments by swapping E0 and E1 in pins_RAMPS.h.
mogul
  • 193
Thomas S.
  • 903
As a quick and dirty solution you may try to enable two extruders in configuration file, re-upload firmware, and then edit your GCODE file to replace all E0 references with E1.
Mikhail Z
  • 868
  • That's a really good idea. It should be possible to have the firmware do it. Or there must be a script that can be ran... But it doesn't seem this firmware is all that great. I would suggest a different firmware if it doesn't do what is needed. – StarWind0 Dec 13 '16 at 02:28
