I have been looking at cork sheet insulation for my 200 mm x 300 mm aluminium PCB heatbed, by I am not entirely sure how thick it should be. There seems to be a trade off between losing a few millimeters of print height, and providing adequate installation.
I have seen 10 mm thick table mats, and then 5/3/2 mm thick cork insulation tiles. On some forums people say they use two 2 mm sheets beneath the aluminium heater and then another 1.5 mm aluminium plate under those, to hold it altogether (source: Re: Is a cork board necessary under the heated bed?).
Hopefully this does not come across as a how-long-is-a-piece-of-string type question. I am just trying to get the right amount in the first place whilst spending as little as possible, and keeping the mass/volume and height down. If someone else has already gone through the empirical adjustments themselves, then it might save me the time and expense of having to test various configurations.
  • Would just 2 mm thick cork backing be sufficient?
  • Is 10 mm overkill?
  • Does silver foil backing help considerably, thereby enabling one to reduce the thickness of the cork?
    Cork is bloody cheap. Why worry -- other than the fact that it's flammable. All that's needed to start a fire is having the thermistor fail or come loose. I'd use a flameproof material if you're going to insulate. – Carl Witthoft Dec 01 '16 at 15:24
  • @CarlWitthoft - OK, thanks, this is the first time that I have really given thought to the flammability issues, although I had read that cork is preferable to silicon/rubbery insulation, due to less noxious fumes being given off. – Greenonline Dec 01 '16 at 16:21
    If you really want to go all out for insulation, buy some [aerogel](http://www.aerogel.org/)! – tbm0115 Dec 01 '16 at 16:29
  • @tbm0115 - :-) That really does look top notch, but is, unfortunately, a bit pricey. – Greenonline Dec 01 '16 at 16:35
    @Greenonline I have to admit that you'd have the coolest looking 3D printer with some of that Classic Silica Aerogel insulating your machine! – tbm0115 Dec 01 '16 at 16:56
  • @CarlWitthoft - As the ignition temperature of cork is 300°C, I wonder if there really is a fire risk. Do you know of any examples of burning, or scorching, of cork, when used as a heatbed insulator? Please see my question [Has anyone experienced scorching or burning of cork heatbed insulation?](http://3dprinting.stackexchange.com/questions/3122/has-anyone-experienced-scorching-or-burning-of-cork-heatbed-insulation) – Greenonline Dec 02 '16 at 11:08
  • Burning cork is difficult even when you WANT it to burn... Cork is the outer layer of trunks and has specifically the goal of protecting the plant from fires. I would say almost no flame risk. – FarO Jun 06 '19 at 12:28
Since 50% of the bed is uninsulated, you're definately into diminishing returns as soon as you start adding any insulation.
With that area, I think you are looking at 1.2W per kelvin for a 2mm thickness.
I'm guessing a bit with these powers, but roughly, maybe from 100 W un-insulated, 75 with 2mm, 60W with 4mm. You can get a reasonably accurate measure of the power by looking at the duty cycle of the heating element.
Actually, its not clear if your primary goal is to reduce energy/maintain a very high temperature, or speed the initial heating. You can place a temporary sheet of cork on top of the bed (preferably extending over the edges to prevent convection) and this will significantly improve heat-up times.
Sean Houlihane
  • 3,712
  • 39
  • Many thanks for the answer. I think that I see what you mean, but just to clarify a few points: By _diminishing returns_, you mean that each increase in insulation thickness gives a correspondingly reduced _increase in actual insulation_ (which, I guess, would make sense)? Are the figures of 100/75/60 W relating to the power used to maintain the heatbed at the same temperature (i.e. 70°C)? Without (necessarily) wishing to get into the mathematics too much, are those figures for the power, _guesstimates_ based on experience or did you arrive at those figures using a formula? – Greenonline Dec 03 '16 at 23:06
    Yes, doubling the insulation doesn't double the power saving. The numbers are guesses, I need to work more on the maths for a real answer. – Sean Houlihane Dec 04 '16 at 00:07
    Also consider cork on top of the bed during heating. – Sean Houlihane Jan 06 '17 at 21:48
    Yes, that is a good idea... I remember reading somewhere that someone suggested even corrugated cardboard helps. – Greenonline Jan 06 '17 at 22:37
