I have a hypothetical question. From which parts can I build a metal-based 3D printer and can I buy those parts somewhere?
    Hi, Bartosz, and welcome to 3D printing SE! I have put your question *on hold* for being *too broad*. This is because your question currently is too general, making it impossible to give a *specific, correct* answer. (For instance, someone might think you want to build a 3D printer out of metal, while others might suggest that you automate a furnace - two spectacularly different answers.) Please have a look at [our help page](http://3dprinting.stackexchange.com/help) for more information on how to ask here at SE. Good luck! – Tormod Haugene Nov 25 '16 at 07:47
I think this depends on what you are trying to accomplish with the 3D printer.
I have seen people online build metal 3D printers from a robot arm and a welder this would probably be the simplest design and build but robot arms that can weld are expensive.
I have also seen that someone at MIT build a glass 3D printer by building a small kiln with a hole at the bottom and moving it around like a normal extrusion printer. This method might work for a metal printer as well if you could get the temperatures right. This might be cheap enough a hobbyist could do it as well because you just need the same parts as a normal FDM 3d printer just able to more more weight. But with the same parts you could also do lost pla casting and that would be a simpler approach with a better end product.
But probably what you would be really interested in building would be a laser sintering 3D printer. Where a layer of powder is put down and then a laser melts part of the powered to join it to the model. For this the main thing you need would be the laser. I don't know a lot about how these printer work but the laser would need to be able to melt metal so I would think it would need to be very powerful and that would make it very expensive.
user802599
  • 636
