I am trying to use my M3D printer that doesn't work with my Linux computer. I have been told that OctoPi would make it work.
My current setup is:
  • Raspberry 2 without WiFi, with OctoPi running
  • Keyboard and touchscreen connected to the Raspberry
  • A .obj file located in /home/pi/ on the Raspberry
I don't know anything about OctoPi, but it seems to be created to use as a print server connected by WiFi.
My question is: how can I use it locally, directly on my Raspberry?
NOTE: I can only use my Raspberry in command line for the moment, but if required I can install lightdm to display stuff.
SteeveDroz
  • 173
  • If you install a web browser on the raspberry pi, you can access octoprint from there (by going to localhost). Is this what you're after? – Tom van der Zanden Oct 22 '16 at 10:02
  • Have you considered maybe using wired Ethernet, the way OctoPrint was originally designed to work, as described by most Octoprint installation guides, skipping the optional WiFi setup -- [a](http://www.instructables.com/id/Newbies-guide-to-Installing-configuring-Octoprint-/), [b](http://www.akeric.com/blog/?tag=octopi), [c](http://reprap.org/wiki/OctoPrint), [d](https://learn.adafruit.com/octoprint-open-source-host-software/octopi-ready-made-octoprint-os-disk-image), etc. -- instead of WiFi? Normal wired Ethernet cables work fine for me. – David Cary Oct 23 '16 at 01:48
To use it locally you need to be able to view the desktop.
sudo raspi-config to pull up the config menu and enable boot to desktop.
If there is no browser installed already you'll need to install one.
sudo apt-get update
sudo apt-get install epiphany-browser
Open the browser and navigate to http://localhost/
I recommend configuring access control when it prompts you. After you configure it, click login in the top right and login to use octopi.
ALTERNATIVE
octocmd is a command line interface for octoprint. If you would rather not boot into the desktop then this is the way to go.
Airfield20
  • 459
