Repetier host 1.6.2. Used Slic3r and CuraEngine in RH1.6.2 to slice my prints.
OK, I've a problem.. Z offset does not work.. Well..
- Flashed EEPROM clear.
- Enabled EEPROM and CHIT CHAT within firmware.
- I've set -0.4 in Marlin firmware 1.0.2-1 stable and flashed it.
G28; home axis = works G29; auto level = works G28; it goes to home and then sets Z to 0.4 G1 Z0; brings nozzle down from 0.4 to 0, so this works also.
But when I slice with Repetier host 1.6.2 with latest slicer / curaengine, it does not go down 0.4 mm before starting to print. I've set first layer to 0.2mm, but when it starts printing the first layer, it goes from 0.4 (after home Z is on 0.4) to 0.6 instead of 0.2! ...
How to fix this?
Gcode start: ;Generated with Cura_SteamEngine 15.01 ; Default start code G28 ; Home extruder G29 ; Auto level G1 Z15 F100 M107 ; Turn off fan G90 ; Absolute positioning M82 ; Extruder in absolute mode M190 S35 ; Activate all used extruder M104 T0 S230 G92 E0 ; Reset extruder position ; Wait for all used extruders to reach temperature M109 T0 S230 ;Layer count: 226
UPDATE: It's definitely Repetier or it's slicers. I'm using Cura 15.04.6 and it also calculates the offset set in marlin when printing! I'm trying to use Cura 2.1 because it's newer, but I do not get the print usb option in Cura 2.1 :/
UPDATE 2: I just don't get it, it was printing very nice the first 4 layers, and suddenly it moved up more than 0.5mm and continued printing there, in the air.
