Cutting to pieces
To cut the ring into pieces you can take the intersection() of the object and the quadrant of interest (e.g. using a cube, but a wedge would have worked as well).
* Möbius Strip
* r: radius of strip
* w: width of strip
* t: thickness of strip
* The model uses $fs to adjust the smoothness.
module moebius_strip(r = 1, w = 1, t = 1) {
step = $fs;
for(azimuth = [0 : step : 360]) {
x = r * cos(azimuth);
y = r * sin(azimuth);
translate([x, y, 0]) {
rotate([0, azimuth/2, azimuth]) {
cube([t, step, w], center=true);
$fs = 0.5;
xloc=[0,1,-1,-1,1];
yloc=[0,1,1,-1,-1];
//quadrant = 4; // 1, 2, 3 or 4
for(quadrant = [1 : 1 : 4])
intersection(){
translate([xloc[quadrant]*10,yloc[quadrant]*10,0]) moebius_strip(r = 30, w = 15, t = 1);
translate([xloc[quadrant]*10,yloc[quadrant]*10,-(30+15/2)/2]) rotate([0,0,(quadrant-1)*90]) cube(30+15/2);
Since tabs and slots are requested, we need to make some adjustments.
Add/subtract tabs to piece
All that is left to do is to cutout a "rectangular" shape at the interfaces. For that we glue or union() a tab on one side and extrude or difference() a tab on the other side, a wedge is used for the intersection() with a smaller sized width Mobius strip.
echo(version=version());
//debug = 0;
//explode = $preview ? 0.1 : 0.0;
//$fn = $preview ? 90 : 360;
//nearly_zero = $preview ? 0.005: 0.0;
tol = 0.01;
* Möbius Strip
* w: width of strip
step = $preview ? 2 : 0.5;
module wedge(h,r,a)
th=(a%360)/2;
difference()
cylinder(h=h,r=r,center=true);
if(th<90)
for(n=[-1,1])rotate(-th*n)translate([(r+0.5)*n,0,0])
cube(size=[r*2+1,r*2+1,h+1],center=true);
else
intersection()
rotate(-th)translate([(r+0.5),(r+0.5),0])
rotate(th)translate([-(r+0.5),(r+0.5),0])
xloc=[0,1,-1,-1, 1]; // vector indexed by the quadrant, negative value is the negative x-axis
yloc=[0,1, 1,-1,-1]; // vector indexed by the quadrant, negative value is the negative y-axis
offsetVal=0; // can be used to explode the view
quadrant = 1; // 1, 2, 3 or 4 resp. for xy, -xy, -x-y or x-y
//for(quadrant = [1 : 1 : 4]){ // now commented to used single single quadrant
difference(){ // for extruding the tab
union(){ // for adding the tab
intersection(){
translate([xloc[quadrant]*offsetVal,yloc[quadrant]*offsetVal,0]) moebius_strip(r = 30, w = 15, t = 1); // Mobius belt
translate([xloc[quadrant]*offsetVal,yloc[quadrant]*offsetVal,-(30+15/2)/2]) rotate([0,0,(quadrant-1)*90]) cube(30+15/2); // quadrant cube
intersection(){
moebius_strip(r = 30, w = 7.5, t = 1); // Mobius belt with smaller width
rotate([0,0,(quadrant-1)*90]){
wedge((30+15/2), (30+15/2), 10); // intersect with wedge to get a tab that extends the quadrant piece
intersection(){
moebius_strip(r = 30, w = 7.5, t = 1+tol); // Mobius belt with smaller width and increased thickness for better cutting out negative tab
rotate([0,0,(quadrant-2)*90]){
wedge((30+15/2), (30+15/2), 10); // intersect with wedge to get a tab that extrudes the quadrant piece
Note that this takes some time to render (F6), the preview (F5) didn't even show because of too much elements. Just change the value of quadrant = 1; to 2, 3 or 4 for the other segments.
Please note that the image from the question is not what is created with the Mobius script, to generate that object rotate([0, azimuth/2, azimuth]) needs to be changed to rotate([0, azimuth, azimuth])
