Recently, I accidentally shorted out my heater cartridge when trying to do my first nozzle swap on my Prusa MK3S+. I just ordered a new E3D v6 Hotend with 30 W Heater Cartridge and it will be here in a few days. I just cut the wire from my heater cartridge to my heat block (long story short, I can't remove it from the block). I'm not sure I understand exactly the wattage though. The heater cartridge that came with my Prusa MK3S+ is 40 W. Does that mean the actual cartridge or the plug into the board? Also, can I just solder the existing 40 W wires to the new 30 W cartridge? If so, does it need to be a precise solder (I'm not very good at precise soldering) Finally, can I just wrap the connection in electrical tape? Sorry for so many questions; this is my first time trying to understand the electrical component of 3D Printing. Any help would be appreciated.
I can't replace my individual heater cartridge because the screw was melted in. I checked my mainboard fuses and they are fine. My printer still powers on, all the motors work fine, and even the bed heater works. I cut the wires at the heater cartridge and left them in the air not touching, and now it thinks it's heating up, so I think that I can deduce that the wires were touching the heater cartridge, and I wasn't able to separate them. Unfortunately, I don't have a wire crimper and am trying to keep this fix as simple as possible.
Note:
After using a 30 W heater on my MK3S+ for a while, I started getting thermal runaway problems somehow, and I have switched over to E3D Revo Six for the safer PTC heating element.
